      El Dorado Hills, CA
      68 Camaro - rear shock relocation options?
      I have seen the BRP setup and the Competition Engineering setup and the Chassisworks setups and all the them pose the problem of exhaust routing in the factory location.... I have 3" exhaust in the factory location and its all mandrel bent, and I want to keep it and not be forced into going back to turndowns... I want to relocate the shocks inboard for more tire clearance on my stock wheel wells and I have seen and read about options and they are all about the same. I wanted to see if there is a chance of using a set of stock upper shock mounts like the factory ones here:
      http://summitracing.com/parts/GMK-40...7/?image=large
      I would simply mount them in the trunk and use my existing shocks and use the Caltracs inner mounts... Would that work? I can then put the shocks anywhere I want correct, thus not interferring with my 3" mandrel bent exhaust......
      I am looking at running an 18x10 in rear stock wheel wells, more on this in the wheels/tires forum... This would give me the ideal setup and the shocks would not rub the tires..
      Opinions, thoughts, etc?
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Milwaukee, Wi.
      Look at smith racecraft, I'm using their relocation kit on my Nova. The best setup out there in my opinion.
      May 2002
      Northern California
      I know what you are looking at (Goodmark link) but those are thinner than the 1/4" plate that is welded to the trunk/frame pan. You can cut and relocate those if needed.
      However....
      The shocks a should not pose a problem when running rims larger than 16". Your interference will come from the leaf spring and wheel tub itself.
      What was your BS again?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Den Helder, the Netherlands
      Country Flag: Netherlands
      I'm running 17x10 on my 67 with the shocks in the original location. I did massage the inner fenders and did some cutting near the stock mounts but I did not touch the mounts. No rubbing.
      El Dorado Hills, CA
      Cool, this is a big help, thanks guys. I was hoping I wouldn't have to relocate, I know on 15x9 with 275/60 drag TA, I had the shocks rub the tires... So since I am increasing the rims to 18's I should be good.
      Hey Vince I am looking to go to a 5" BS on a 18x10 with my rearend shortened by 3 1/4 with willwood discs, this should allow me to have the wheels still centered and leave about 5/8" on either side on the tire.. For the leaf spring interference you are referring to the rear of the leaf correct?
      Brad
