Results 1 to 19 of 19
Switch from DOT 4 to DOT 5...problems?
I recently installed Willwood disc brakes on all 4 corners and switched out the master cylinder. Willwood recommends a DOT 5 fluid for daily driving with their systems. Will there be any issue if I fill the new resevoir with DOT5 and then flush out the whole system to get rid of the DOT4? I wasn't sure if there would be a reaction between the 2 since it is not recommended to mix the 2 together.
