    Results 1 to 20 of 22
      Jun 2009
      Ok, I just made that first post in that section to introduce myself. I welded the seam solid on a lap weld. Some time I will do the plugwelds on the part that is overlapped. I am also wondering if I do a bunch of heat shrinking along the seam. It's not really warped but maybe there's some extra tension in that area from the welding. I also was told of a type of filler primarilarly for marine use that is so ridgid that it won't do that shadowing. A friend uses it in a custom and restoration shop and thinks it will be the cat's meow. I will let you know when I do it. I'm glad I was referred to this forum.
      Tnx.....
      Derrick
