Results 1 to 19 of 19
08-23-2004 #1
Another smoothed firewall question
I welded and filled my firewall earlier this year before I put the car on the rotisserie.
I don't like leaving the seam, and opted for a full smooth look.
The problem is it took a lot of filler to get it all flush and smooth.
I am now back on the firewall and as you would guess it, noticed a crack starting in a spot.
So...I am digging it all out now.
All the large holes are filled with metal. The wall is just so wavy and imperfect that it will be impossible to make flat without lots of filler.
So...is it possible to cut one large flat piece and weld it from edge to edge, grind it, then only apply filler as needed at the seam?
I also want to get rid of the indention just behind the motor. I am running an LT1 so I don't need any indention for a distributor.
Chris McDonald
