    Thread: Alignment specs
      Jan 2007
      Pittsburgh, PA
      Alignment specs
      It's time to align my car for the first time, and am doing it myself with the SPC tool. I have no clue what it should be set at, and hope someone has some input. It's a 78 TA with Pro touring F-body uppers (solid bushings) with 5 degrees camber built in. Lowers are stock with rubber bushings. all steering components are new. Hotchkis drop springs. Running 17" YO snowflakes with 255/45 (if that matters). I'm assuming a 1/16th toe in would be ok, but have no clue what a good caster/camber combo would be. If anyone can give some input, I'd really appreciate it. Thanks alot.
      Terry
      78 TA, 400 4spd
      72 Chevelle, 454 4spd
      72 Demon
      72 Dart
      70 Dart
      70 Charger
      69 Roadrunner
      55 Chevy
      70 Duster
      68 GTO
      ...ain't projects fun?
      USA
      The Guldstrand Engineering website lists the following specs:
      For a Touring Car:
      1/4' to 1/2' neg. Camber.
      3' to 4' pos. Caster
      0" to 1/8" Toe IN
      With a little disclaimer : " These settings represent a place to start. Optimum setting for each track or driving techniques must be determined by testing. "
      The settings for a Racing car or Slalom car are different.
      It is sometimes good to give about 1/2' more positive Caster on the passengers side.
      An example , if you have 3' pos. caster on the drivers side , then put 3 1/2' on the passengers side.
      This helps compensate for the crown of the road.
      Guldstrand link:
      http://www.guldstrand.com/alignment.asp
      Jeff Tate
      U.S.A.
      Jan 2007
      Pittsburgh, PA
      Thanks for the info. At least I have a place to start. This may be harder than I thought though. Good to be learning something new.
      78 TA, 400 4spd
      72 Demon
      72 Dart
      70 Dart
      70 Charger
      69 Roadrunner
      55 Chevy
      70 Duster
      68 GTO
      Aug 2005
      Hamilton, NJ
      That's right about where my 77 Z28 is, except I run a bit more caster.
      Scott from NJ.
      Vent Windows Forever! ...
      Quote Originally Posted by Phishfud View Post
      It's time to align my car for the first time, and am doing it myself with the SPC tool. I have no clue what it should be set at, and hope someone has some input. It's a 78 TA with Pro touring F-body uppers (solid bushings) with 5 degrees camber built in.Terry
      I hope you mean 5° caster.
      Jan 2007
      Pittsburgh, PA
      Oops. Yep, that's what I meant. Just a typo.
      78 TA, 400 4spd
      72 Demon
      72 Dart
      70 Dart
      70 Charger
      69 Roadrunner
      55 Chevy
      70 Duster
      68 GTO
