05-27-2009 #1
Pinion angle and traction....myth?
How can pinion angle effect traction or wheel hop? I have been in a long running debate over this issue and thought I'd run it past you guys. I know there is a lot of info out there on the Internet and a lot of drag racing literature on this subject but I am having a hell of a time understanding this phenomenon. Think about it for a while and it's seems impossible for the actual pinion angle to have any effect on traction. The rear end pinion is attach to the driveshaft by a floppy u-joint and has no effect on how far the rear end housing rotates. Pinion angle should only be set for optimum drive line alignment after trailing arms , link bars and location devices have been set for optimum traction. If you're saying that by pointing your pinion down X amount of degrees is improving your traction, I'm saying it's not the angle of the pinion that helped but that you changed something that improved your instant center. Did you shorten your top bar to get the pinion down? Well now your drive line is out of whack!
I'm not trying to start a war over this but it is a subject that comes up often and I feel it's a little misunderstood.
Perhaps it's just me that's being dense.
Frank
Truck guy.
