    Results 1 to 20 of 26
      Oct 2005
      New Washington, IN
      help with idle problem TBI camaro!
      I just pciked up this car for a new daily driver, and am having an idle problem I can not figure out.
      First the car info.
      1992 camaro rs. 305 TBI 5 speed tranny. All stock.
      When I got the car, the po said it needed a tps sensor, said it was bad, when ever you turn on ac it dies.
      Well, I check it out, and the tps sensor was unplugged. plugged it in and it seemed a little better, you could turn on the ac and the motor kept running.
      Well, you drive the car around, and come to an idle, and the car dies.
      First code it showed was a 53.
      I replaced the alt and tested it. It is fine.
      I cleaned out the throttle body with sea foam deep creep.
      Replaced the IAC valve.
      Did not change.
      Next code came up was 32.
      I checked the vacume lines for the egr. All are clear.
      Changed the egr control solinoid.
      Did not change .
      Still showing a 32.
      Changed the egr valve.
      Nothing changed.
      Still showing a 32 and 53 came back on.
      I disconnected the vacume hose from the egr and drove it.
      Nothing changed.
      Can anyone shed some light, point ,me in the next direction?
      I posted this on thirdgen.org but have gott nothing from there.
      It does not seem to be affected by temps. Happens 99% of the time.
      It will typiclly idle for 15-20 seconds before dieing.
      This is making it a real pain to drive!
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Jun 2006
      Indianapolis,IN
      The TBI injection units were notorious for blowing the base gasket and creating a vacuum leak between the throttle plates. The IAC motor cant adjust for the leak so the car dies at idle. I would be willing to bet that if you look in the TBI you will see gasket hanging out one side between the the throttle plates. Its a quick inexpensive fix. Hope this helps.
      Tim
      Oct 2005
      New Washington, IN
      Awsome.
      Thanks for the tip!
      Oct 2005
      New Washington, IN
      I replaced the tb gasket. It did not look blown, but was worn out.
      It did not fix the idle issue.
      I am no longer getting any trouble codes though.
      Dec 2007
      arizona
      sounds simple but have you checked the fuel filter friend was having same problem at idle changed the filter fixed the problem hope this helps can't hurt
      Folsom, Ca
      thse injectors are quite old now as well, hows the spray pattern look?
      Oct 2005
      New Washington, IN
      Spray pattern looks good, until it starts to stall and they just start to break up spatter.
      Oct 2005
      New Washington, IN
      I'm gonna change the filter this week. I tried to other day, but did not have the right wrenches.
      I ran some lucas fuel cleaner through it when I got it.
      Southern Indiana
      UHm ok so why change alternator for a code 53 that is a VATS code in 92, and code 32 testing depends on which EGR valve it calls for or an SIR problem.
      Who is giving you test procedure for these codes. Email me and Ill try to save/send the actual test diagram for the EGR code and for the VATS test.
      Now does this car have VATS? and did you actually check to see if the alt was over voltaging as it needs to go over 16.9 volts. Which vin do you have E or F?
      Oct 2005
      New Washington, IN
      e vin
      does have vats
      Had the alt under warrenty so, figuresd it wouldn't hurt to change.
      I know the 32v means different egr info depending on the motor.
      It is a 305 so it does not have the electronic egr the 3.1 has.
      Just basing my testing off the haynes manual.
      Oct 2005
      New Washington, IN
      Changed the fuel filter, did not change.
      Also swapped the TPS sensor.
      Did not change anything.
      Check your fuel pressure?
      Oct 2005
      New Washington, IN
      Not yet. I guess I'll have to do that next.
      Southern Indiana
      EGR Testing Part 1 Of 3
      EGR Wiring Diagram
      CIRCUIT DESCRIPTION :
      The ECM operates a vacuum solenoid to control the EGR valve. The solenoid is normally closed. The ECM provides a ground path to energize the solenoid. This allows vacuum to flow to the EGR valve.
      The ECM monitors EGR effectiveness by de-energizing the EGR control solenoid thereby shutting off vacuum to the EGR valve diaphragm.
      With the EGR valve closed, manifold vacuum will be greater than it was during normal operation and this will be relayed to the ECM by the map sensor. If the change is not within the calibrated window a Code 32 will set.
      The ECM control of the EGR valve is based on the following inputs;
      • Vehicle speed is above 50 mph.
      • Manifold pressure is between about 60-70 kPa (BARO 100 kPa) at low altitudes or through 30-40 kPa (70 kPa BARO) at the higher altitudes.
      • TPS is between 9% and 20%.
      • No more than 0.4% change in the TPS while the test is being run.
      TEST DESCRIPTION : The numbers below refer to circled numbers on the diagnostic chart.
      1. Intake Passage : Shut "OFF" the engine and remove the EGR valve from the manifold. Plug the exhaust side hole with a shop towel or suitable stopper. Leaving the intake hole open, attempt to start the engine. If the engine runs at a very high idle speed (up to 3000 rpm is possible) or starts and stalls, the EGR passages are not restricted. If the engine starts and idles normal, the EGR intake side passage, in the intake manifold, is restricted. Exhaust Passage : With the EGR valve still removed, plug the intake side hole with the same stopper. With the exhaust side hole open, check for the presence of exhaust gas. If no exhaust gas is present, the EGR exhaust side passage, in the intake manifold, is restricted. NOTE : Remove towel or stopper once test is complete.
      2. Grounding the diagnostic test terminal should allow the EGR solenoid to energize, and vacuum should flow to the gauge. The vacuum at the gauge may or may not bleed off slowly. It is important that the gage is able to read the amount of vacuum being applied.
      3. When the diagnostic test terminal is not grounded, the vacuum gauge should bleed off through a vent in the EGR solenoid. The vacuum gauge may or may not bleed off, but this does not indicate a problem.
      4. This test determines if the electrical control portion of the system is at fault, or if the EGR solenoid and/or connector is at fault.
      5. EGR valves used with this engine are stamped "P" for Positive and "N" for Negative. See EMISSION CONTROLS , for "EGR IDENTIFICATION," under COMPONENT OPERATION , to assist in determining the type of EGR valve used.
      DIAGNOSTIC AIDS :
      • Vacuum hoses should be thoroughly inspected for proper routing.
      Southern Indiana
      Notes EGR Testing Part 2 Of 3
      EGR Wiring Diagram
      The ECM control of the EGR valve is based on the following;
      • No more than 0.4% change in the TPS while the test is being run. The ECM control of the EGR valve is based on the following inputs;
      1. The remaining tests check the ability of the EGR to interact with the exhaust system. This system uses a POSITIVE BACKPRESSURE EGR VALVE which will not hold vacuum until sufficient exhaust backpressure is at the base of the valve.
      2. The EGR valve diaphragm should move when sufficient exhaust backpressure is present at the base of the EGR valve and when vacuum is applied to the valve. Rapidly snapping the throttle from idle should provide sufficient exhaust back pressure to the base of the EGR valve, which will close an internal vacuum bleed. With the EGR valve's internal vacuum bleed closed, the jumpered vacuum supply can now lift the valve off its seat.
      3. Excessive exhaust back pressure from bent or restricted exhaust system components, could provide enough back pressure to the base of the EGR valve to close the EGR valve's internal vacuum bleed and allow undesired EGR valve operation at idle.
      4. A Plugged EGR exhaust passage can stop exhaust back pressure from reaching the base of the EGR valve. If this takes place, the EGR valve's internal vacuum bleed may remain open, and prevent vacuum from operating the EGR valve.
      DIAGNOSTIC AIDS :
      • Suction from shop exhaust hoses can alter engine back pressure, and may affect the functional test of the EGR valve.
      Southern Indiana
      EGR Testing Part 3 Of 3
      EGR Wiring Diagram
      1. The remaining tests check the ability of the EGR to interact with the exhaust system. This system uses a NEGATIVE BACKPRESSURE EGR VALVE which should hold vacuum with the engine off.
      2. When the engine is started, exhaust back pressure at the base of the EGR valve should open the valve's internal bleed and and vent the applied vacuum allowing the valve to seat.
      Southern Indiana
      Code 53 vats issue
      Code 53 Chart
      Wiring Diagram For VATS Circuit
      The VATS (Pass-Key) system is designed to disable vehicle operation if the incorrect key or starting procedure is used. The VATS decoder module sends a signal to the ECM if the correct key is being used. If the proper signal does not reach the ECM on circuit 229, the ECM will not pulse the injectors "ON" and will not allow the vehicle to start. A Code 53 will set if the proper signal is not received on circuit 229. A Code 53 is not stored in the ECM memory, but is only present when the above conditions exists.
      1. If the engine cranks, and a Code 53 is stored, it indicates that the portion of the module which generates the signal to the ECM is not operating, or circuit 229 is open or shorted to ground. If the decoder module is found to be OK, the ECM may be at fault, but this is an unlikely condition.
      2. If the engine will not crank, this indicates that there is a VATS problem or an incorrect key or starting procedure is being used.
      Southern Indiana
      Well here are the 3 step testing for code 32.
      Southern Indiana
      OK now if it has vats pellet in key measure it with ohm meter , make a resistor pack that is equal to that value and go find the tiny orange or white wires under dash coming out from column and simply solder it in tada no changing bs ign cylinder. There are 15 different combos, I hate doing the cylinders so I just Jump the wires and tada never have to deal with broken wire ever or expensive keys.
      Oct 2005
      New Washington, IN
      I have not had any codes show up in the last few days.
      Disconnecting the egr vacume line and plugging it had no effect. I would think if the egr was the issue, diconnecting it would resolve the issue.
      Tested fuel pressure. It is a solid 12 psi.
      Tested resistance of the injectors. one was 3.4ohms the other was 3.8. Swapped one out, and it did not change anything.
      The vats code was due to the key being worn out. Got a new key made.
