      Jan 2009
      Wilwood rear brakes
      ok so i'm mocking up my rear brakes on my camaro and it appers that the spacer that mounts the caliper bracket to the inner drumm is to think? is this normal or have i done something wrong?
      Josey Sandy
      have'n a badass car and not driving it is like having a playboy model as a wife and not......well, you know.
      Aug 2003
      There are multiple washers in the kit so you can shim the caliper and / or the caliper bracket in and out to center the caliper on the toror. Just use one of the smaller washers, or a combination of washers till you get the correct fit. When it is rght the caliper should be balanced / equal on either side of the rotor
      Jan 2009
      thats just it its set to far away from the disk. it needs to move in
      Josey Sandy
      Aug 2003
      So can you remove some washers? Do you have the right kit? What axle do you have? What ends? What is the offset of your axle? What kit do you have?
