Results 41 to 60 of 72
No sweat, we've all been there. It sounds like either you're misinterpreting the definition of drop spindle or I missed something about what's on the car now. Let's back up. The part that bolts between the UCA and LCA and that the brakes mount to is the knuckle. The shaft that the bearings and wheel mounting hub slide onto is the spindle. Where that shaft is located on the knuckle is what defines whether it's a stock spindle or a drop spindle. A "2 inch drop spindle" is a knuckle that has the spindle located 2 inches higher than normal; by raising the centerline of the wheel 2", you effectively drop the rest of the car that same distance. Thus the term "drop spindle". Either style will accept a big brake package. Again, talk to the brake supplier of your choice; chances are they'll have both a stock height spindle and drop spindle as options.
If you decide to buy the spindle from a different source than the brakes, you will have to make sure the brakes will fit that spindle. That's why it's easier to get them all from one vendor.
You'll go thru the same thing again when you buy wheels and tires. That/those vendors will need to know your brake and suspension package to make sure the get the size and backspace right to clear the caliper, rotors, sway bar, etc. All of the good ones will know what questions they'll need answers to.
Bob
Mooresville, NC
'66 Chevelle SS (461, T-56)
https://www.pro-touring.com/forum/vb...?do=view&g=274
05-26-2009 #2Thank you, you just did a woorrllldddddddd of clearing things up for me. I guess I was a little bit confused by youre previous post, when you mentioned your coilover drop spindle setup. I thought you said that you WOULD NOT go with 2 inch drop spindles when using coilovers becuase it would mess up the geometry of your ride.
But now i understand that it is possible to use the drop sinples aslong as i get my spring rate where it needs to be from the manufacturer ( DSE)
Secondly, I currently have the stock 307 SBC in the car that im trying to get started, if im able to accomplish this i dont have to worry about dumping all sort of money in the 454 (that im planning on stroking out to a 496) i have in the garage that needs to be worked up. i.e Instead of spending 2 3 grand on the bb right now i can spend it on the suspension like i am planning to.
My question is with the coilover setup + the 2 inch drop spindle's would it give me enough defecit ( want a real low front end) to order bbc chevy springs on the coilovers because eventually i do plan on going with the bigger motor?
this is the stance i am shooting for.
"Project Yeti"
70 Chevelle Coupe
BIGGER is BETTER...
Bigger Engine !!..........
Bigger Wheels !!!.............
Bigger AUDIO !!!!..................
http://www.youtube.com/watch?v=SjIRkWENUxM
05-26-2009 #3
