    Results 1 to 12 of 12
      May 2006
      power steering pressure ?
      What is the basic fluid pressure from a gm type II power steering pump?....Getting ready to make the lines and am not sure on the hose pressure ratings...The pump is a hi flow unit from wegners any help would be great Thanks
      Aug 2006
      Roswell, GA
      Max pressure is somewhere between 1000-1500 psi dpending on how the pump is set up. Use hose rated for at least 2000 psi.
      1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost.
      Newbury Park, CA
      Lee's set mine to 1450 psi @ 3gpm.
      GR, MI
      I know this is a little old but maybe someone can use this info. I am using the regular braided hose and aluminum fittings on my power steering and have been for at least 5 years now. No problems. It's not technically rated for the pressure but it works fine.
      Auburn, WA
      Quote Originally Posted by Hotrod406 View Post
      Are you serious?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Quote Originally Posted by HotRod406
      I hope nobody uses this "information". Most ordinary SS braided hose is rated at 300 psi, which is 5-7 times underrated for power steering. This is just a bad idea, and can potentially have serious consequences.
      jp
      ​John Parsons
      Phoenix
      I can't recall where I got it from but I made some P/S pressure hose out of a steel braided teflon hose and a hose end slightly different than your regular AN fittings. I thought I got it from Speedway Motors but can't find it now on their website. I don't know anything about this place but I found some here http://www.delikon.com/teflon.html
      Mountain Springs, Texas
      Russell makes teflon lines pressure rated hose and fittings that you can get from Summit.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Henderson,NV
      Don is right on the money. They aren't much fun to make, but I used them on my ride. You have a ticking time bomb there hotrod.
      Todd
      I'm using the Russell teflon hose. It works fine, and is rated for power steering, but I want to swap it out for some Brown and Miller stuff:
      http://www.bmrs.net/smooth_bore_2-2.htm
      jp
      ​John Parsons
      Newbury Park, CA
      jp,
      That looks like a standard industrial Aeroquip crimp-on fitting. You should be able to have a local shop build something similar. That way if you have two 90's on a hose you can clock them before the final crimp.
      Morehead City, NC
      Change them out with Aeroquip TFE hose and fittings before they kill you.
      Mike
