    Results 1 to 1 of 1
      LSX Filter Regulator w/#6 Fittings
      Regulates the correct constant 58PSI required for your LSX. We have used this filter/regulator combination in 800HP forced induction builds. Typically mounted near the fuel tank, and allows the use of stock, return-less OE rails so factory or aftermarket injector covers can be used.
      For more info and To order: http://www.speedinc.com/cont.cfm?cid=C0000896
