    Results 1 to 10 of 10
      jasper IN
      Shockwave Titanium Series
      The latest advancement is performance air suspension is the new shockwave TITANIUM series. The high pressure monotube design and remote oil reservoir of the shockwave Titanium allow the ultimate in ride and handling control. The low drag seals and micro-smooth piston rod allow instant consistent reaction to road irregularities and driver input as well as minimize heat buildup within the shock. 16 position compression and rebound valving are completely independent from each other and provide a wide range of precise, repeatable tuning opportunities. The new Titanium series ShockWave also incorporates as standard equipment the Internal Ride Height Sensor that won a SEMA Best New Product award in 2008. This means you can now have world class ride quality, razor sharp handling, and automatic leveling in one simple package!
      Available for most Streetrod and Musclecar applications, the ShockWave Titanium is yet one more step in the pursuit of “no-compromise” performance both on the road AND on the track.
      • Monotube Design – allows a larger piston design for better response and control
      • Remote oil reservoir – adjustable gas pressure and larger oil capacity keeps oil cooler and foam free
      • Dual valving adjustments – completely independent compression and rebound valving adjustments allow a wide range of performance potential
      • Built-In ride height sensor – no external sensors to mount and calibrate
      • Low drag seals and micro-smooth piston rod – enhances consistent operation and durability
      Jason Brady
      www.ridetech.com 812-482-2932
      The Guy who invented the first wheel was an idiot. The guy who invented the other three was a genius.
      Aug 2005
      Patterson, NY
      Sweet!!!
      Jason Scheer
      Jan 2000
      Thousand Oaks California
      Awesome!
      Larry Callahan
      west michigan
      those look awesome. I like those way better than the aluminum look.
      Chad Read
      Jul 2007
      sweden
      what price point are those
      as it says a price would be nice
      looks awesome btw
      camaro69-l92 with 6l80e considering mast ho cam 530hp - speedtech(LCA)-ats Street-Comp AFX-unisteer r&p - VariShock coilover QuickSet2-Hydratech Brake Booster - 5gen rear suspension
      movit brakes 380mm 6piston front-465mm 4piston rear - 275/30-19 front-325/25-20 rear 19x9f 20x12r cray scorpions
      wow... simple and sick
      1967 Firebird 400 4 speed
      4 wheel c5zo6 brakes + hydroboost
      18"sterns wrapped in RE-11's
      Jul 2003
      Anaheim Hills, CA
      You guys are missing the MOST important aspect.. they are MONOTUBE now..
      1968 Track Rat Camaro:
      Looks great... Wonder what this is going to do to the price of the street challenge kit im about to get. When will these be available?
      Zack Campbell
      Nov 2007
      Vancouver, WA
      AFCO reservoirs?
      1970 Dodge "E-Tikit" Challenger
      Oct 2006
      Carlsbad, CA
      Sexy!!! Me want some.
