    Results 1 to 19 of 19
    Thread: Chop Saw?
      Oct 2007
      Southeastern MA
      Chop Saw?
      I'm finally starting on building the chassis for my P/T project and have run into a snag. I bought a cheap,Chinese 14" abrasive chop saw and put a decent DeWalt wheel on it. The saw really struggles when I'm cutting angles in.120 wall rect. tubing on it-the cross-section that the saw sees is quite thick and the saw just chokes. No kidding,it took me an hour to make two 45 degree cuts in a piece of 1-1/2x3 tubing last night.
      I see Milwaukee or DeWalt saws for sale but, before I spend more $$ I want to be sure the tool will meet my expectations. The specs are actually the same as the cheap saw I bought. I would love to have a cold saw but it's out of my meager price range.
      What are you guys using to cut chassis tubing quickly and accurately?
      Jan 2009
      Suisun City, Ca
      I have the milwaukie one and it struggles too. I recently saw a video on one called a Evolution Rage and it seems pretty good for the price. Best price I found was about $350
      Michael Hunt
      Suisun City, CA
      St Louis, MO
      This is what you want. This thing is unstoppable.
      http://www.ridgid.com/Tools/614-Dry-...w/EN/index.htm
      Couldn't give you a price b/c I get it at cost.
      Jul 2002
      Mesquite, TX
      The Google says it's about 725 bucks. Very cool looking saw though.
      Walla Walla, WA
      Quote Originally Posted by derekf View Post
      Northern Tool has two cold chop saws for (IIRC) $370 (house brand) and about $470 (DeWalt).
      Mike Kelcy - '68 Camaro with some stuff done to it.
      DeWalt and Makita make similar saws to the Ridgid. I've got the DeWalt saw, and have used the Makita in the past. Recommended, especially for steel and aluminum. Just not getting abrasive dust everywhere makes the whole fab experience a *lot* nicer.
      The downside to these saws is that they won't handle stainless. I don't care what the manufacturer says. I've ruined at least 5 blades cutting stainless for exhaust sytems, even when using blades supposedly designed for stainless.
      Now... if you want the best solution, use this:
      http://www.vansantent.com/Saws/porta...ndsaw_ev90.htm
      I will own the EV91S some day. It's an incredibly accurate saw, runs on 110V, new blades cost less than $30, and it can be taken to the job.
      One day...
      jp
      ​John Parsons
      Jan 2009
      been using the same makita for about 4 years now and built atleast a dozen frames for various cars. i love it
      Oct 2007
      Southeastern MA
      Thanks for the input,guys. I had no idea cold saws had made it to the "portable,home-user" stage. I'm looking at the Evolution and the Ridgid. I've just come up from my shop again after spending an hour and 45 minutes making two cuts with the offshore saw. I'm done with that piece of c**p. I really like the no-dust aspect of them,too.
      I prefer the Makita to the DeWalt. I bought the DeWalt since it was a 14" saw to the Makita's 12", but I think the Makita was more accurate and had longer blade life.
      jp
      ​John Parsons
      Elgin, IL
      X2 on the Dewalt Multi-cutter
      We only use it on structural and solid bars and it chews thru everything. No stink no dust. I found it at HF for real cheap, they called and tried to replace with something else because it was out of stock, I told them I'll wait.
      Dan
      Oct 2007
      I bought a dewalt off of craigs list. Guy used if for 1 project then it sat so he didn't mind selling it cheap ($75.00) I highly recommend looking on Craigs list.
      67 Camaro In progress
      Apr 2008
      Anaheim, Ca
      My milwaulkee cut through a 6 inch piece of stainless that was 3/4 inch thick just fine... took about took maybe 2 minutes. My dad said it would take forever when he brought me the piece and it blew through it in my opinion. Although I did buy a reinforced blade from KBC tools that is good for stainless, actually bought 3 blades thinking they'd never last. It didn't look like it wore all that much when done.
      The chunk of stainless was hotter than all hell when said and done.
      Kenneth N.
      1969 Mercury Cougar XR-7 Boss 429 clone under construction
      Dec 2007
      Cleveland, ohio
      Quote Originally Posted by cheapta View Post
      the saw is fine it's the blade buy a metal cutting blade made of steel you will love it. bob
      1971 Chevy Nova SS
      Pro Street Touring
      6-71 Blown 400 Dart Block-800 HP
      LS1 Stage V T56 Transmission W/ Pro 5.0
      McLeod Street Twin Disc Clutch
      Ford 9" 31 Spline 3.90 Platinum Tru-Trac
      8-Point Roll Cage
      Martz Racing 4-Link Back Half
      Martz Racing Front Half
      Coy's 18" Wheels
      Recaro Seats W/ G-Force 5Pt Harness
      Feb 2009
      MA.
      i have a dewalt i got at a swap meet paid $50.00 about 5 years ago still going strong no problems yet
      Nov 2007
      Afton,Mn
      Quote Originally Posted by blown71 View Post
      Isn't the metal blade made for substantially lower rpm than the abrasive? Do they make a metal blade that can cut at 3600+ rpm?
      Right. Check the speeds. I think the metal cutting blades run at 1800 rpm or so.
      jp
      ​John Parsons
      Jul 2009
      Abbotsford,B.C.
      jp
      cold cut saws are the cats meow for cutting metal straight , unlike chop saws .metal blades run at a lower speed . When using a chop saw you are suppose to break the surface & continue to chop at the work piece .
      Rockford Illinois
      You can actually cut steel with one of the cordless saws and the carbide blade for metal cutting because of the lower rpm and the torque they have.
      get plenty of batteries and your good to go!
      Jun 2009
      Waco, TX
      Quote Originally Posted by Jim Nilsen View Post
      O Rly?
      I have a DeWalt 18V circular saw - one of these:
      http://www.dewalt.com/us/products/to...productID=8184
      you can get carbide metal blades for it?
      I use it frequently for ripping through a random 2x4 or something quick and dirty, pretty handy to have (rather than pulling out the big saw).
      1979 Z28 - Project BubbaZ, receiving LS2/6-speed/APS Twin Turbo setup
      1994 Z28 Vert - 383'd, cowl'd, spoil'd, slam'd fun
