    Results 1 to 12 of 12
      Oct 2005
      Orlando, Fl
      Borgeson Steering Shaft Installed
      Got all the parts in and finally got time to get the new steering shaft installed. Did a little driving and it feels good. A little more steering/road feedback, but no vibration. Also cleared up a lot of room near the alternator for those doing LS swaps and need more space. I had ground the side of the alternator down and was worried about the alt going bad out on the road (750 miles each way to Chevellabration) and not being able to easily swap it. The shaft needed to be cut down 8.25" to make it 18 3/4".
      Parts:
      Upper U-Joint: 1-48 x 1 DD (214352) Aluminum
      Lower U-Joint for GC box: 1 x 3/4 DD x 3/4-30 (214931) Aluminum
      Telescoping Shaft: 1 x 24" Extended Length (450024)
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Feb 2007
      Tinley Park, IL
      Very nice!
      Is this a straight up swap using the parts you listed?
      I'm using a factory column and factory gear box.
      Nick ~
      1969 Cutlass
      So. Cal.
      Looks good. I dont see any tell tail traces of loctite. You did use some right????? JR
      Oct 2005
      Orlando, Fl
      Quote Originally Posted by Mr Nick View Post
      Very nice!
      You would just need a different lower U-joint. Not sure on the factory gear box size/spline count. The lower part listed is for the Grand Cherokee box. You would need Stock Chevelle size/spline count - 3/4DD, but the shaft and upper will work fine.
      Michael Barnes
      Oct 2005
      Orlando, Fl
      Quote Originally Posted by JRouche View Post
      Not yet. I need to move the upper over one spline to get the wheel straight again. The directions just say retighten after 100 miles. I guess a little blue couldn't hurt.
      Michael Barnes
      Central Florida
      Quote Originally Posted by stealth71 View Post
      I've run their steering shaft on my Jeep for about 8yrs now. They are well built. BTW- I did not use Loc-tite (I've had no problems...and I beat the crap out it) but it does add a margin of safety.
      Patrick
      So. Cal.
      I red loctite many steering and braking fasteners that are not normally removed for service. JR
      Feb 2008
      Fort Worth, TX
      Did you have any trouble getting the top U-joint onto the steering column? I bought the same setup for my 70 GTO and it is impossible to get it on very far, maybe 3/8" max. I thought maybe I bunged up the splines, but the stock one goes back on easily. Just wondering if you had any problems.
      Avery
      05 Caddie CTS-V (daily driver)
      76 914 with 95 993 engine (driven every nice day)
      70 Pontiac GTO 455 (long term project)
      Sep 2007
      Southern California
      This is a nice setup! I went with the same shaft and used the steel u joints in my 68 GTO.
      x2 on using the loctite!
      Jon
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      Oct 2005
      Orlando, Fl
      Quote Originally Posted by Grngoat View Post
      No problems getting it on. Could you car possible have a different column? Did you try counting the splines?
      Michael Barnes
      Feb 2008
      Fort Worth, TX
      It could, but it's a stock GM column anyways. I think they are all 1"x48 as far as that goes.
      Somethings not right, though. I'll figure it out eventually. It's still just a roller, so no hurry.
      Just curious. Nice looking car btw.
      Avery
      Jun 2006
      Katy,TX
      I'm using one on a 79 Camaro and the oval portion is about 0.015 larger than the steering column so it rock some on the through bolt giving a little free play in the wheel.
