    Results 1 to 8 of 8
      b-ville MD
      sbc rockers & guide plate question
      I have been told that I CANNOT use self aligning roller rockers with guide plates. Is this so, and what would be the reason behind it?
      Thanks,
      gmchevolds
      May 2000
      They could bind against each other.
      Why would you want to? If you have sa rockers, remove the guide plates.
      b-ville MD
      ok I will, thanks
      Feb 2008
      Sesser, Il
      In case you don't know, if you remove the guideplates you must run a washer of equal thickness under the rocker arm stud or it can throw off the rocker arm geometery and you'll need shorter pushrods.
      Doug Gulley
      66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
      b-ville MD
      Yea, I figured that, thanks.
      Southern Indiana
      Just dump SA rockers and use guide plates, much more reliableBesides stacking washers or some type of spacer is not the best way to do it.
      Apr 2008
      Newark, OH, / Concord, NC
      Washers
      The use of washers or spacers is not neccesary unless the adjuster nut does not fully engage the stud, adjust the rockers without washers or spacers and if there is at least two threads showing above the nut you will be good to go, if you are using poly locks you need about .375 to .500 thread engagement
      Dale
      b-ville MD
      thanks
