    Results 1 to 7 of 7
      Crown Point, Indiana
      Cooled down starter still hot, wont start
      I Drove car to store car won't start with a jump. battery is showing full power. Car has cooled off and starter motor is extremely hot. The Solenoid kicks hard I'm, stuck may need to call for a trailer any suggestions.
      evansville, in
      sounds like its grounding out inside. and will prob not be rebuildable. if you were closer id come help you out. sory to hear it.
      A guy brought his trailer for me to use and once we got it on this is what the problem was. looks like the starter was engaged from the time I left home (about 15 miles)
      Thanks for the offer 6994lt1
      May 2000
      Have you fixed it?
      Probably needs to be shimmed out.
      No it is still hanging up. I am running a mid plate so that makes the distance even greater.
      Southern Indiana
      So why are you using the aftermarket starter,,, are you using a large flywheel or small one, if large one just go buy the small frame starter for a 94 K2500 w 350 AZ part number DLG9990S. I have seen these start 572 big blocks with extra compression and never give a problem, but you do need bolts from dealer. And the AZ starter has lifetime warranty.
      Honestly I have more problems with these aftermarket units than I care to mention.
      Good Luck
