Results 1 to 14 of 14
Thread: GTO LS2 - 68 Camaro
04-20-2009 #1
New to Pro-Touring
- Oct 2007
- 47
GTO LS2 - 68 Camaro
I am about to pull the trigger on an LS2 engine and t56 out of a GTO for my 68 Camaro. Are their any issues with this swap that would be unique other than the typical LSx swap issues. Anything unique to this combo to deal with? I also plan to use the GTO accessories.
_________________________________
Chris
1968 RS/SS
04-20-2009 #2I put this combo in a 69 Camaro, not done yet though. My 2 cents worth:
Make sure your engine adapter plates and headers work together. I have ATS plates (turned upside down from ATS directions) and Stainless Works headers, I'm told on here that will work with no clearance issues but haven't verified myself yet.
I modified a stock LS1 oil pan and pickup myself, if I did it over again I would get the Autokraft pan and bolt it on and be done.
I'm using stock accessories for now, A/C wont fit though, not sure what I'm going to do, probably S&P kit to add A/C to main belt. My alternator hit the subframe a bit but I rotated the backhalf of the case around for clearance, then a little touchup with a grinder and it fit fine. This was done before I flipped the ATS motor plates upside down from their directions.
Good luck,
Erik
04-20-2009 #3
New to Pro-Touring
- Oct 2007
- 47
04-20-2009 #4
