      Jul 2008
      Maple Ridge, BC,Canada
      Bosch 75 amp relay
      Ok, so I am an electrical r-tard.
      wiring up my high speed taurus fan. Got the relay, but not familiar with reading symbols on relay that identify whch pin/post is which.
      Any elec gurus here help me?
      which pin/post is which - 86-85-87-30
      70 Nova - 406 sb -488 HP/504 TQ-3:73's
      http://s66.photobucket.com/albums/h266/steelratnova/
      Central Cal
      Go here http://relays.tycoelectronics.com/telectronics.asp
      look for V23232-A/-D High Current Devices, High Current Relay 75
      Its a pdf. file.
      It will show you what you want to know.
      Jul 2008
      thanks so much, very helpful
      appreciate it
      Southern Indiana
      Pretty simple if you LOOK at relay, heavy wires will hook to big lugs, the 2 small spades ar for low amps ie the 85/86 terminals of diagram.
      Now watch those diagrams as the relay has a diaode inside to damp voltage spikes into computer controls. The little arrow agains a flat line is a diode, a squiggly line would be a resistor, the diode will only clamp voltage spikes in one direction, if I see pic right the 85/86 termianls on diagram actually may have a +or - on them.
