Thread: brake pedal stays down?
03-15-2005 #1
- Aug 2004
- Phoenix AZ
- 286
Power brakes with C5 fronts and stock drums for now (will be C5 rear next week). Got a show to do thursday and just decided i needed to get it road worthy so bled the brakes, everything went well there. During test drive noticed pedal wasn't coming back up all the way. one time the brakes still had pressure to them when i shifted into second. Just used my foot to pull up on the pedal and they released. Any suggestions on where to look for the problem?
03-16-2005 #2Sticking pedal
I suppose the first thing I would check would be the linkage and return springs on the pedal, be sure they are not binding or sticking or that they don't have any electrical wiring in the way. Second check out the rubber components...I would be sure there is no swelling in the master cylinder cap or square cut O-rings internal to the caliper, perhaps you have contamination issue and things are really hanging up!! Do the brakes get excessively hot during short distances? Can the car be pushed while in neutral on flat level ground? If not you might also check operation by isolating the system fromt the power booster...I have seen Booster cause brakes to Drag and/or cause the same problem your having. Hope this helps.
03-16-2005 #3
