    Thread: G-Body LCA
      Aug 2006
      Cibolo, TX
      G-Body LCA
      I am trying to decide between:
      Currectrac LCAs (johnny joints on the frame side and poly on the rear end side), or
      Global West LCA with the Del-a-lum bushings on the rear end side and a spherical bearing on the frame side.
      Any thoughts, experience, or advice?
      Rob
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      dayton, oh
      i'll be using the Currectracs since the johnny joints are rebuildable and last longer than the spherical bearings.
      dave.t
      74 Javelin AMX - stocker
