      Nov 2004
      Eastern Washington
      Cheap paint gun for primer
      I am looking for a cheap paint gun for laying down some etching primer to protect some new sheet metal for a while....any ideas of an acceptable one for around 25-50 bucks...dont want to spend too much on it.
      Houston Texas
      i found a TON of fairly decent paint guns on Ebay for $1 + $15 shipping. So it still comes out to a good deal.
      http://motors.search.ebay.com/paint-...4998QQsbrsrtZl
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      Nov 2004
      Eastern Washington
      Think they will do a decent enough job? I want a cheap one, but not necessarily a crappy one.
      Jun 2002
      Long Island, NY
      I bought a pretty cheap craftsman spray gun, to paint small misc. parts and such. I think it was like $60 bucks? I haven't used it yet, but it looks to be pretty good.
      Jul 2002
      Muskegon, MI
      Most any Craftsman type gun will work well for primer. Top feeders are my personal favorite. Just try to get a tip thats around a 1.6 and you should be all set. If its a little bigger that will be ok too . You will just have to sand a little more thats all.
      Nov 2003
      Maine
      gun
      i would suggest a 1.8 to 2.0 for urethan primers, i spray my first coats with my 2.0 tip gun, then after blocking i go to a 1.6, for a smoother finish, but the purpose of the primer is to build the surface , so you are able to block sand it straight, so you need to put some primer on it, any gravity feed 1.8-2.0 will work good, and you do not need a smaller for 2nd coat, 1.8-2.0 will work great
      jake
      Oswego il
      ive had good luck with the harbor freight gravity feed guns, dont know if you can specify tip size. the one i had i ruined shooting epoxy on a bathtub, so they werent all that great for that application but it came out nice with trial and error. for $40 it isnt a big deal to throw them away.
      Jul 2002
      Tempe, AZ
      This is the one I bought:
      http://cgi.ebay.com/ebaymotors/ws/eB...544132697&rd=1
      $35+$10 shipping. It comes with an adjustable regulator, 1.4mm tip for painting and a 2.0mm tip for priming. I've had mine for 2 years and it's a great quality gun for the money- real solid and trigger pull is very smooth. You can use the 3M PPS system with it as well- it takes the #2 adapter. I have painted some parts with it using the 1.4 tip for basecoat and clear and they came out great. Haven't used the 2.0 tip yet but I used the 1.4 tip to primer a truck and it worked really good.
