Thread: Concerned about my new Wilwood's
New to Pro-Touring
- Sep 2004
- 75
I just finished installing my rear disc brakes. Everything seemed to go together fine until I installed the caliper. The outside shoe is tight against the rotor. The caliper comes with shims, but they would only make the problem worse if installed on the caliper bolts. Am I missing something?
03-12-2005 #2you may need to shim the oposite side of the bracket that bolts to the cars rearend to pull the caliper back and make sure its straight with the axle hub, when I installed 4th gen calipers and brackets they didnt exactly fit straight on a 30 something year old rear end
Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
03-12-2005 #3
New to Pro-Touring
- Sep 2004
- 75
Seems to me that if I place shims there the retainer will not have adequate tension on the bearing and it may have play. Grinding the spacers on the caliper mount sounds better to me, but this can't be right.
I'm installing a brand new moser 9" assembly. I should not have to be grinding spacers to make it work.
03-13-2005 #4it sounds like you may have a problem with the axle standout . ford rears have 3 different housing ends . i assume you have the large brg. ends which use either a 2.5 standout for the late big ford ends or a 2.33.for the early big ford. the axle and brake manufacturers make there kits in both dimensions. it sounds like you have a mismatch. and no you cant shim the mount on the housing. this would allow the axles to float in and out. i hope this helps.
Originally Posted by 69speed
03-12-2005 #5The bracket that holds your calipers on also holds your wheel hubs in is that what your saying? I still have c-clips on my camaro so we may have completly different setups. I did have to put 1 washer in between the bracket on two bolts to get it to be in line with the rotor
03-13-2005 #6
