      Jun 2008
      Victoria, TX
      Need help with a rear end measurement
      Im looking into getting a FAB9 from my buddy, but I dont know what size it has to be narrowed and neither does he. Im wanting to run an 18X12 with a 335 can someone help me. A buddy of mine has this rear end, will it work for me??
      FAB9 with
      A Strange Engineering:
      35 Spline Detroit Locker Carrier 3:50 Gear Ratio
      Street/Strip Axles with 5/8" Wheel Studs
      Wilwood Part # 140-2274
      Rear Axle Disc Brake Kit
      Vented Rotors, Parking Brake ( 2.36" offset )
      Big Bearing Ford
      Pro Street Disc set-up with separate Emergency Brake Caliper
      Dimensions:
      53" from Disc Rotor Wheel Mount to Disc Rotor Wheel Mount
      38 1/2 from Center to Center Leafspring Pads
      im wanting to run a g bar or g link with it. I just wanna make sure this will work before I buy it from him monday, i put a pic of it can you please help. thank you
      IF YOU DONT STAND BEHIND OUR MILITARY FEEL FREE TO STAND IN FRONT OF US!
      -HOOAH-
      Dec 2002
      Lost Wages, Nevada
      Narrowed to go into what exactly ??
      I ask that because what you have described... is narrowed... if you are talking about a first gen F/X-body. From your description... it is 7 inches narrowed from a OE housing dimention of 60". 7 inches would allow you to run a a 12" wheel with ease without any further modification to the width of your housing. That would put your backspacing around 8 to 8.25'ish... and give you a real deep dish.
      Next question... will it work for you ?? I dont know, what is it that you are trying to accomplish ?? The 5/8" wheel studs are a little over kill and can make rim modifications necessary just to get them mounted to the axle. Other than the back brace making it a little more involved to get a G-Bar/G-Link mounted and its increased weight... it looks lke a solid set up for a high power drivetrain.
      Is it worth the cash layout to you ?? If so... do it. I dont see any standout problems that would interfear... other than mounting the links to the housing with the back brace and all... but, that shouldnt be an issue really.
      This is a drag race rear end. It sounds like you want to do auto cross or road racing. You don't need a drag race rear end for that. It will be more trouble than it is worth. You need a rear end that is built for what you want to do. The Detroit Locker is much better for drag racing than for road racing. You need a Trutrac for road racing or auto cross. You also need a housing that is built for your needs. When getting a custom rear end the first thing that you need to get are the wheels and tires. You put them under the car and measure the distance between the mounting flanges of the wheels. That will give you the total width of the rear end. Then you order the rear end to that width. My advice is to pass on this and get the right parts.
      Jun 2008
      Victoria, TX
      im a little confused so you say it will and will not work. im building a ls2 with a procharger with a t56/ maybe around 500-500 horsepower. I do wanna do the whole protouring idea. i wanna be able to drive the car 300 miles and still have no worries about anything. my buddy want 2000 for the set up, and i was hoping it would have worked out for me due to the price. but im wanting to get some forgeline rims the 18X12 335 mega tire in the rear, but if this rearend set up will cause problems i guess I will pass..
      -HOOAH-
      If you were building a drag or pro street car then this would work. It's not a pro touring rear end.
      Aug 2003
      Sorry,, but it it is 1 1/2" to narrow, below the minumum for the G Bar. With a G Bar bar you are not going to ba able to put the perches on it, they will be on the housing ends. You will have to widen the rear to a minumum of 54 1/2" to be able to fit the brackets, and prevent brake to suspension issues.
