Results 1 to 9 of 9
Thread: a-body with coil overs
03-19-2009 #1
New to Pro-Touring
- Jan 2009
- so cal orange county
- 34
I'm looking into coilovers for the a-body qa1, varishock,afco,koni,bilstein,dse
Which ones works I saw dse and varishock at the goodguys show last weekend and got there views but is anybody running a set up for hard street driving and weekend autocross.
Harsh rides don't bother me.
I was looking into afco but they don't have an a-body package you need to make measurements.
Let me know
03-19-2009 #2Have had QA1's on the frt of my Chevelle for awhile and just finished installing the full DSE suspension on the rear. I used QA1 450 lb straight rate springs to help get the nose up to proper ride height (2" drop spindles installed previously and car has big block w/ aluminum heads & intake + A/C). Rides fine, not too stiff, handles great.
Haven't done any driving with the DSE stuff yet, install was very straightforward. Just a few holes to drill. Will be interested to compare stock rr suspension (except for Hotchkis lwr trailing arms and sway bar) vs. the full DSE treatment (coilovers, rr suspension incl. SwivelLink arms, and sway bar). Can't beat DSE customer service either.Bob
Mooresville, NC
'66 Chevelle SS (461, T-56)
https://www.pro-touring.com/forum/vb...?do=view&g=274
03-19-2009 #3
New to Pro-Touring
- Jan 2009
- 34
What did all that run for the rear set up I saw it at the show and it look great on the display but i haven't seen or heard anybody with it installed.
Let me know I only have the Hotchkis springs,boxed arms and upper arms right now.
03-20-2009 #4Website prices Speed Kit 3 at $2345 all in with the base shocks, more if you want double adjustables or remote reservoirs.
http://detroitspeed.com/productpages...ar-spd-kts.htm
Individual components are available -- coilovers, SwivelLink arms, adjustable chassis braces, sway bar -- if you don't want the whole kit. Not shown on the site but I know they're available, call DSE.
If you have the Hotchkis sway bar that mounts to the Hotchkis lwr arms, it won't work with the tubular DSE arms. However the DSE sway bay may work with Hotchkis lwr arms since it doesn't attach to the arms, it attaches to the axle housing and the chassis.
Before I took them off my car I noticed an interference between the Hotchkis boxed lwr arms and the lwr bracket for the DSE coilovers; something to ask DSE about, might not apply to your yr/car and not an issue at all if you use their lwr arms.
BTW, QA1's frt prices also change for the various shock options. I have double adjustable on mine. Given how easy to install and well engineered the DSE stuff is, I'd have gone with their full frt suspension setup had it been available when I started piecing mine together 5-6 yrs ago. I used Belltech drop spindles and Hotchkis ctrl arms when I installed the Baer brakes and added Baer tubular tie rod adjusters. The sway bar and end links were on the car when I got it. The parts all work well together but I'm sure the kit from DSE, being engineered as a system, would be a bit better. For me it's not logical to drop $2600 replacing the solid stuff I already have, which is what their frt Speed 2 kit costs.
The clinching thing for me is the level of product and service you get from DSE. If you've ever had a chance to talk with Kyle or Stacy Tucker you can see how committed they are to their customers and the rest of their staff is the same way, great people all around.Bob
Mooresville, NC
03-20-2009 #5
