Results 1 to 10 of 10
Thread: rear return system questions
- Aug 2004
- Phoenix AZ
- 286
Took my 70 GTO to the tuner, FAST XFI, aeromotive A1000 inside Ricks tank, Aeromotive return style regulator mounted at tank and Aeromotive filters. Everything is plumbed with -10 for feed and -8 for the short return. Right away he told me it would not work the way I had it, he was concerned about the fuel going through the regulator, he thought the regulator would be a restriction that would cause the engine to starve for fuel. He recomended putting an additional -10 hose using t-fittings at the inlet and outlet, bypassing the regulator to help feed the engine. Have you guys had any problems that required this kind of fix?
Second question concerns no fuel at rails during restart, I have to let the pump run two or three times before the car will start. it seems that the fuel is returning to the tank and not staying at the rails. kind of stinks having to turn the key on and off three times before it will start. any easy fixes here? maybe a check valve of some type?
thanks for the help guys.
03-19-2009 #2You may need a check valve to keep the fuel from draining back to the tank. I don't recall hearing about this being an issue, but you never know.
It might also be a case of vapor lock. Since there is no return near the engine the heat gets to soak right into the fuel lines, possibly boiling the fuel. This is why OEMs (usually) had the regulator on the return line, so the pump could push fuel through the lines and clear any vapor.
Now, as for the regulator, I don't know how the Aeromotive ones work, but I thought that the return style regulators work by restricting flow to build the pressure to the proper level. I think you would T the regulator off the feed line so it can bleed off the excess pressure.Jason Scheer
03-19-2009 #3
