    Results 1 to 20 of 94
      Dripping Springs, TEXAS
      Project Throttle: 1972 Camaro
      On January 28 1997(2 days after my birthday) I was going around looking for a 1970-73 Firebird Formula or T/A.. On my way back to the house from looking at a 1973 Formula that was so rigged and full of bondo that even I didnt want to mess with it. I came acrossed a 1971 Camaro RS that had its nose sticking out in the street with a FORE SALE sign in the window, he really had it spelled like that..:D Anyways, I had to stop to look at it since it was only $1600 dollars. I got to looking at this car and noticed that the back window was getting ready to fall in, he says that it would be a easy fix.. I tell him this car is going to need both quarters,both trunk extensions and fenders, as I am walking around the car to see how bad it is I see a car under a tarp.. I ask him what that is and he says that is a 1972 Camaro with a 327/TH350 and it is all there and has a title.. It has been drug down a poll on the driverside. He wanted $500 for it, I ask if it runs. He says it will run but only for 10 second or as long as he can poor gas down the carb, I tell him I will give him $300.He says $500 and I can go through his stash of parts.. I say OK..I went to his storage and grabbed just about everything I could put in my truck..
      So that starts my journey, back then I was just a High School kid trying to build a cool car.. I got the car to my garage and started to see what the deal was with the fuel. I checked the fuel lines, and everything and couldnt find anything wrong with it.. So I kick the key on and nuthing comes out of the fuel line at the motor. He had the electric fuel pump in backwards.. Easy Fix, turned it around and look at that it fires right up and runs fine.. This is what it looked like when I took it off his lot and got it to my place..
      The Car lasted a couple of weeks and then the cam went flat from him trying to start it and only run for 10 seconds while break in.. So I pulled the motor and decided I was going to rebuild the motor, the bottom end was good. So I bought a Cam, lifters and pushrods and started there.. I also Ported and Polished the heads. Well my luck sucked and the motor in my daily went south and I had to use everything for the Camaro in the 62' C10 and when I got that motor installed in the Truck it turned out to be just to much motor for a daily driver(283 bored .030 with 480 lift cam and 11.2 to 1 compression), it makes 430hp at the crank @ 7200 rpm.. So the Camaro when on the back burner while I paid off my new daily driver. I bought a 2000 GMC Sierra 4.8L V8 hoping I wouldnt get the bug to mod it.. Well, I did and this is what it looks like today..
      So that took me five years and then I started working on the Camaro again..I started with repairing the windshield and back window area. Then new quarter and trunk extensions on along with some patches for the passenger quarter..
      Back Window.
      Windshield
      Her are some pics of the qaurter panel work.
      POR15 on the stuff that is going under the quarter.
      New Quarter on.
      Then the Car went on the backburner again when I got the urge for a motorcycle again..
      That is where this fast little ******* came into my life.
      2007 GSXR 750
      Instead of Working on my car on the weekends I was riding this thing and loving it.. On October 18 2007(almost one year after buying it) I went down hard on it, I highsided off of it in a diesel soaked road and landed on my shoulder instantly blowing my collar bone in many many peices.. I found out that day that the guy had shoved a rag in a hole in his fuel tank and when he went through the turn the fuel pushed it out and poured all over the road. Needless to say I sued him and the company for it and was able to get back on my bike along with getting much needed parts for the Camaro... :D
      Here is the rest of the project in pics because I am sick of typing..
      http://www.flickr.com/photos/2641401...7603998601359/
      This is what is looks like right now. So it took me alot of breaks and 12 years to get here, but it is worth it..
      Here is the rundown of what is done to it..
      Factory Options:
      This car was a base 307ci Camaro from the factory...
      Exterior Modifications:
      Boyd Coddington Rebels 17x8 w/ 245/40/17 front and 17x11 w/ 315/35/17 rear
      Harwood 4" Cowl Hood
      Factory one peice spolier
      Grand Sport Blue with White w/ silver pearl stripes
      Interior Modifications:
      Interior is pretty much all factory style other then the 1990 300ZX Seats and Auto Meter Gauge Cluster..
      Performance:
      Started life as a 1990 SS454 Truck block(4 bolt main).
      Eagle 496ci Stroker Kit-Forged Crank
      ARP Main Studs and Heads Studs
      6.385 H-Beam Rods
      10.2:1 JE Pistons
      Comp Cams Hydraulic roller tappet
      -Basic Operating RPM Range: 2,500-6,200
      -Intake Duration at 050 inch Lift: 232
      -Exhaust Duration at 050 inch Lift: 232
      -Advertised Intake Duration: 290
      -Advertised Exhaust Duration: 290
      -Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in.
      -Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.578 in.
      -Lobe Separation (degrees): 110
      Roller Lifters
      1.7 Comp Cam Roller Rockers
      Brodix Heads
      Combustion Chamber Volume (cc): 119
      Intake Runner Volume (cc): 270cc
      Intake Port Shape: Oval
      Exhaust Port Shape: Round
      Intake Valve Diameter (in): 2.250 in.
      Exhaust Valve Diameter (in): 1.880 in.
      Retainer Material: Steel
      Locks Included: Yes
      Lock Style: 10 degree
      Rocker Arm Nut Thread Size: 7/16-20 in.
      Guideplates Included: Yes
      Guideplate Pushrod Size: 3/8 in.
      Accessory Bolt Holes Drilled: Yes
      Intake Valve Angle: 26
      Exhaust Valve Angle: 26
      Valve Seat Machine Style: 3-angle
      Dart intake
      Single Plane
      850cfm Holley dp
      March Pulley Kit
      MSD Ingnition and Distibutor
      Be Cool Radiator and Fans
      Suspension/Chassis:
      Global West Upper and Lower Control Arms
      Hotchkis TVS Kit
      Blistein Shocks
      2008 Z51 Front Brakes(13.4in rotors)
      SSBC Rear Disc Brake setup
      Master cylinder off of a later model Corvette with Disc/Disc Prop Valve
      8" Dual Diaphram Booster
      All New MOOG Steering Components
      Drivetrain:
      Moser 12Bolt
      33 spline axle and a detroit Locker with 3.73s
      Built TH400 with a 2600 TCI Street Fighter Stall Converter
      Electronics:
      MSD 6AL
      iceland
      Country Flag: Iceland
      Sounds like you got great car there keep posting pics
      Iceland
      I took it back over to my personal garage and getting ready to pull the front end off some I can get the Subframe out to blast and put back in.. Then the fun begins with the engine and suspension..
      Miami
      Quote Originally Posted by Throttle View Post
      don't forget to clean the bottom of the shell
      Already done and undercoated..
      Miami
      good job! Your holding out on pictures I see...LOL
      Dunwoody, GA
      very nice.
      Trey
      ~ Jon Hammond
      Snohomish,Wa.
      Nice Truck! perfect stance and choice of rolling stock.
      Roger
      Thanks, this truck was the first thing I have ever modded to handle..
      I pulled all the sheetmetal off today and pulled the subframe and suspension.. Now I just have to sandblast it and paint it Egg Shell Black.. Should have the front suspension back on it before the end of March.. While it is all off I will do the bodywork on the firewall and paint it Egg Shell Black while im at it..
      Sep 2008
      Southaven, MS
      The car is looking great. Keep up the great work.
      69sleeper
      I finally got around to sandblasting the core support and to no suprise it is trashed, thank god I know how to fix this crap. I would hate to have to buy a new reproduction and have to make it fit..
      Making the patches out of cardboard first..
      Then using the cardboard patches to make the metal ones..
      Now I have to sandblast them and cut the old stuff out and POR15 behind all the patches and start welding them in..
      This is a quick grind of the new patches after being welded in..
      Here is the Subframe and Core Support blasted, I am now hanging them up to spray them plus a couple of other parts..
      Coresupport and brackets, headlight buckets, and subframe..
      :D
      I painted the steering components the other day and set the front suspension on the subframe so I can roll it around to get it away from where I am doing bodywork.. I know Ed Miller is going to kill me, but I had to shave the fins down on the calipers to make them fit.. :( You cant see it until you take the wheel off, so no big deal..
      I just wiped down the new steering parts and cleared them..
      Sandblasted the bolts and cleared them also..
      For some reason I lost the pics of the steering box and idler arm all cleaned up and painted with Detail Gray.. I have the finished pic though..
      Brakes are mighty close..
      Nice work it looks great.
      Iceland
      iceland
