    Results 1 to 16 of 16
    Thread: guide coat
      Feb 2009
      Mobile ,Al
      guide coat
      I have been watching a lot of guys painting their cars on here and after priming they spray it with black paint, almost like a fog .Some have called it a guide coat.What is this for?
      Tony
      Aug 2005
      Patterson, NY
      After you apply the guide coat you block sand it again (lightly) and see where the block doesn't hit (remove the guide coat). These are low spots that you will need to fill in.
      Jason Scheer
      Beaufort , NC
      Yep exactly
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
      Feb 2009
      Mobile ,Al
      Question
      can I use rattle cans for this?
      Aug 2005
      Patterson, NY
      Yes.
      Jason Scheer
      Mountain Springs, Texas
      3M makes a dry guide coat powder that is easy to use. You just apply it with the sponge applicator.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Tulsa, OK
      Isn't that stuff a little costly? How much do you get out of a can of it and about how much is it? Is there a drying time advantage to this vs the spray paint?
      1980 Z/28 383, Vortec heads, 2004R 342.1 powertrac
      1971 Firebird on rotisserie
      2006 Dodge Daytona Charger
      "Torred" # 1988 of 2000
      2013 Hot Wheels Edition 2 SS Camaro
      "I'm Not a Gynecologist, but I'll Take a Look"
      Phoenix,Arizona
      there is stuff that is made just for guide coating, but you can use any contrasting color rattle can, a flat paint works better because it dries faster than gloss and clogs the paper less.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      So. Cal.
      I used Evercoats rattle can guide coat. Great stuff and inexpensive. One can did my whole car. And its a powder when it dries, no gumminess. JR
      Pic before and after guide coat.
      Before
      After
      And after some block sanding
      Aug 2003
      Use laquer for guide coats, won't clog. Walmart has white and black laquer cheap.
      Apr 2004
      OKC, OK
      Quote Originally Posted by manicmechanic View Post
      A container of it will do a couple cars. I love it and won't ever use rattle cans again. Once you see how far it goes, it is cheap, you just pay for it all up front instead of $4 at a time.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Feb 2003
      St. Louis, Missouri
      I use a $.98 black rattle can from Walmart. Works fantastic.
      Rick Butterfield
      Apr 2008
      Forest City,NC
      yep the rattle can from walmart or evercoat rattle can guidecoat,,the 3m powder seems to smear and move around as you block,,i have used leftover old basecoat thinned down in a pinch
      Mark Dorsey
      Near Dayton, OH
      I've bought SEM brand guide coat black that sounds like its the same stuff as the Evercoat brand. Dries almost immediately and comes off easily as well.
      And I found out the hard way that you should use a lacquer based product and not enamel. The enamel will clog the paper so bad you won't get any sanding done. :(
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Colchester, Ct.
      Have to agree with Frank and HFB another tip I always spray my guide coats (rattlecan) when the primer is still wet this way when the primer dries and bodywork shrinks the guide coats goes into any imperfection (sand scratches) and it is easier to see and sand out later JMO.....
      'Veteran' --is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America,' for an amount of 'up to, and including his life.'
      May 2009
      a trick i do is add a small amount of toner to my primer after each coat.. then i can really see how high or low the spot is. just like going from grey to a shade darker to a shade darker.. just a suggestion.. otherwise i prefer the dry guide coat..
