    Results 1 to 7 of 7
      front leaf spring mount
      What are you guys using for a front spring mount when using DSE's tubs and offset rear hangers. I thought I could unbolt the spring pockets and move them to the inside of the frame, or is this unecessary to fit a 315 tire? I plan in using Spedtech offset hangers in the rear and some bolt on spring mounts to the axle. Trilogy does this sound familiar????
      May 2002
      Northern California
      off set
      You won't have to move them for 315's you just loosen the bolts and tweek em over abit then set up your rear perches then tighten the front perch bolts. Now for 335's thats another story.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mar 2003
      Lafayette, In.
      Quote Originally Posted by MrQuick
      335's.....who......what ????
      lmao !
      exactly what vince said.
      i am leaning towards wanting to run 335's but i'll have to widen my DSE tubs more to accomplish this, plus with a 335 i'll have to midify the front spring perch somehow to also accomodate......kinda undecided on 315 or 335
      In process!
      1972 C10
      Roadster Shop Fast Track chassis
      LS376/525
      May 2002
      Northern California
      335's
      ahhhh 335's don't forget you'll have to notch OR move your frame in 1-2". I have a front perch design if your looking to do the 335's. Its just reinforcing the section on the inside of the frame and making a bracket mount.Pretty slick and doesn't hang down at all. let me know
      Jun 2002
      Benicia, CA
      Where the heck were you when I needed those???
      Vince,
      Not sure about Monday as I am going to the rearend shop on Tuesday now. I cannot access the forum from work anymore (old forum still works), my corporate WebSense program works well! Talk to ya soon,
      Jeff Andre'
      Spedtech ?
      LS1 Nova what is Spedtech shackles and how to I contact them. Are they heeper than DSE. Do they have them for 69 Camaros. Thanks,Kevin
      Oct 2003
      Arvada, Co
      Speedtech shackles
      As for the web site I think it is like speedtech-performance.com. Remember sometimes you get what you pay for. The ST shackles are thinner all around than the DSE shackles and they are not hardcoated like the DSE ones. If you want to save some cash than buy the ST stuff, if you want the best buy the DSE.
      Brian
