Results 1 to 10 of 10
Thread: Camaro repro quarter ???s
03-01-2009 #1
Hey guys,
I'm about finished fitting the passenger quarter on my '69 Camaro, but have a few minor fitment issues to resolve first. The repro quarter fits really good, but it bows out around the bottom of the door jam and won't sit flush with the rocker panel. The pics should show this better than I can explain it. Is there a relatively easy fix for this? I may try to put a self-tapping screw into the rocker, but would like to avoid putting a hole in the rocker if possible. When I bend it in where it needs to go, the quarter ends up about 1/8" too high at the top of the door.
Also, the body lines around the tail pain seem too low. Is this common with repro quarters? The upper misalignment is covered by the bumper, so I'm not too concerned about it, but the bottom body line is fairly noticeable. Nothing I can't fix with a little welding, but want to be sure it's not an alignment problem.
Nathan
1969 Camaro - 355 sbc, TKO 600, 12 bolt, Global West suspension
03-02-2009 #2welcome to the world of chinese quater panels. You are on the right track with the self tapper. I use cleco's (aircraft removable rivits) when I hang those, but a self tapping screw will work. The rule of thumb on sheet metal work like this is to just be patient. It is going to take some hammering here and there as well as maybe even some cutting and welding. If it is bowing you might need to cut it, releave it, and weld it back up. Doing this in the middle of one of these quaters is very common. I know what you thinking "i dont want to cut up a new quater panel" but sometimes you gotta do what you gotta do. It still beats bondo'ing up the old rusty one!
03-02-2009 #3
