      Aug 2008
      Do I have the right MC?
      I have started my brake upgrade this past weekend and need to know if the MC I bought is correct for what I am planning. I have the stock brake booster (72 A body), but changed to a big block vette style MC with same front and rear ports. The MC is for a power brake set up with a 1 1/8 bore. The front line is 3/16 to the line lock and the same down to the T block I put in place of the original proportioning block. So the front is complete. The rear originaly has 1/4 tube from the MC to the prop block. With the new MC, it is 3/16. From the MC it is goes 3/16 tube to adjustable prop valve, then to the main line (that I disconnected from the original prop block) which is 1/4. I need to get an adapter for that yet. Does this set up sound correct?
      thanx
      Aug 2008
      Anybody?
      Oregon
      MC bore size should be determined by the calipers you are running. Is this a stock setup or something aftermarket?
      Your hard line sizing sounds fine for a disc/disc setup.
      Tobin
      KORE3
      It's what I does.
      We've debated the hardline sizes before. I don't recall what we concluded. My stuff is all 3/16".
      jp
      ​John Parsons
      Fontana, CA
      jp
      It was concluded that it really didn't make much of a difference for most swaps.
      Nick R.
      Aug 2008
      Thanx all......i kinda figured it out for the most part.
