    Thread: Q-Jet help!
      Parkland Florida
      Q-Jet help!
      I am in the process of installing a Q-jet, actually it is already "installed", but I have a small issue I was hoping someone like Cliff may know off the topof his head. On the back of the carb there is large threaded hole on the bottom of the caar.
      1-what is the function of this black hole?
      2-More importantly, what size is it so I can plug it before it sucks me through it when I am trying to start it!?
      I dont mean to be lazy, but I dont want to take the carb off and take it to a hardware store looking for the correct size.
      Jason
      1968 Camaro convertible. 383ci, 700R4, C5 13" brakes up front and C5 wheels all around. Oh! anda Hydroboost unit too!
      So Cal
      Jason
      Depending on the year of the carb you can plug the hole in the back of the baseplate with either a 1/8 or 1/4 NPT pipe plug. Buy one of each, the ones with and an Allen hex are cleaner looking.
      A vacuum 'tee' fitting would normally go there, they made a variety of different ones for different applications.
      Stop being so lazy.
      Bart
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Parkland Florida
      Thanks Bart, Honestly the hole looks even bigger than a 1/4, but that will get me close.
      Thanks again!
      Jason
      So Cal
      1/4 NPT pipe thread is a lot bigger than 1/4" in size, they size pipe fittings by inside diameter of the pipe if I'm not mistaken.
      If it looks a lot bigger than 1/4" then it's probably 1/4 NPT, if it looks pretty close to 1/4" in size then it's 1/8 NPT.
      Parkland Florida
      Thanks, I am going to buy both when I hit the parts store!
      Little Rock, Arkansas
      Bart is exactly correct. That's where the vacuum T goes in for all the manifold vacuum devices.
      Parkland Florida
      1/4 was right on the money!! THANKS!
