      Boise, ID
      Bilstein Hotchkis Rear shocks
      I just went to install my rear shocks in my mono leaf shock plates on my 68 camaro and it looks like I will have to drill out the shock plate hole for the lower shock bolt?? It seems as if there won't be much material left after I drill 5/8 hole through the shock plate....anybody done this??
      Brian
      Dec 2002
      Lost Wages, Nevada
      ...Have always used the steel sleeve insert that came in the box from Bilstein... and the factory bolt size. Never drilled the holes... I always used the sleeves.
      This is something you could get from Bilstein in Poway, ASI is El Cajon... or even ORW would most likely have these laying around.
      Boise, ID
      Thanks Chicane..so the sleeve goes in the lower shock "eye" and then the bolt through the sleeve?
      Dec 2002
      Lost Wages, Nevada
      That is correct.
      Boise, ID
      Found them at Summit Racing!
      McAllen, TX
      looking for the same thing! Have a part number for them?
      Armando Garcia
      67 RS/SS Camaro
      07 Ford Mustang GT/CS
      02 Harley Davidson F-150
      McAllen, TX
      still looking for the part number! i saw a few of them but not sure exactly which size is the one i need! HELP!
      Armando Garcia
      67 RS/SS Camaro
      Newbury Park, CA
      Have you tried contacting Hotchkis?
