Thread: quick question
03-05-2005 #1
- Aug 2004
- San Antonio, Tx
- 1,193
quick question
is a 9.0:1 engine to much compression to spin two hair driers for about 750 horse on pump gas?
have been reading all day and haven't found a solid answer everything says 8.5:1 when building one.
Instagram: CamaroAJ
03-05-2005 #2
Starting The Transformation
- Aug 2004
- Alta Loma,SoCal
- 396
You can do it. You will need to be very careful in your tuning. Pay special attention to the intercooling.
1965 Buick Skylark
03-06-2005 #3Unless your combo is already built, I'd go with 8.5 max & let the boost do the work. With 9:1, and only looking for 750, why go twins? Granted- they'd be more street-friendly, but is it worth the cost & weight?
03-07-2005 #4
- Aug 2004
- San Antonio, Tx
- 1,193
i am on kinda of a tight time and money budget, the bill mitchell 427 small block has 10.0:1 with 64cc heads so i figure with AFR 76cc heads that gives me about 8.8:1 or so. i can get a real good deal on them from a friend that is the over seas part import guy at jegs so i was kinda tring to go that way. i know it would be easy with a NA engine to make that kinda power but i want the street friendly and the abilty to crank it up sometime down the road to more horse. also as far as i can find out there insn't alot of TT PT cars in the columbus area so i wanted to be a lil different then the show cars and pro streeters.
Instagram: CamaroAJ
03-08-2005 #5A BM 427, and on a budget? Dude- for that, get it built exactly how you want.
