      Netherlands
      Driving tips for Time atack
      My frind and myself are going to run a Time atack race on former F! race track in the netherlands. we are new at this type of competition. all driving tips!!!!! are welcome. car hase 461ci 550 hp engine 13 inch 4 piston brakes up frond 12 inch single in the rear, tire rim combo 255x17x8 and 315x17x11 in the rear. 4 speed autom(tr2004r L3 ), and all the other goodies.
      Dec 2008
      Lehigh Valley Pa
      Slow in fast off, always be smooth, And always remember that the chassis and tires can only do so much work. So try not to upset it with sudden moves be it steering input, baking, shifting or acceleration. When going into a corner I get on the brakes, smooth increasing to a hard push. It is all one movement nice and smooth but it ends up being quick, just not like jumping on them And then once the chassis is set downshift to the proper gear for the corner. Roll out of the brakes and smoothly apply power. When you look at the track work backward from the longest streaight on how to attack it as the last corner before the longest straight is the one you want to get right the most so you can carry the most speed onto it. Then you can work back from there to figure out your line. Late appex is almost always the best bet.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      What class and type and model car are you running ?
      When you get in my car, you realize ...... Monsters are real !!!
      Aug 2001
      Connecticut
      Make sure your brake pad and tire selections are good. One problem area for these Time Attack and time trial events, you don't get a lot of warmup time (1 lap normally) before the hot run, not enough time to really properly heat the tires or brakes. It's easy to get in trouble that way.
      As far as driving, if you can get your car to a club driving school- do it, you'll learn the car and driving. You should never be coasting, which is easier said than done at first. Slow down to go fast, work on smoothness first.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Netherlands
      Quote Originally Posted by EPYON View Post
      68 firebird. Semi Prostreet Time attack.
      http://www.streetpoweredition.nl/
      http://www.streetpoweredition.nl/ind...catid=6:nieuws
      Nice !!
