      CT
      Difference between LS1 and LS6 pistons??
      Just curious?? Anything?
      Sep 2008
      Kathleen, GA
      02+ LS6 pistons got moly coating on the side skirts, that's all i can think of..
      CT
      any compression difference??
      Sep 2008
      Kathleen, GA
      no...same design, same dimensions
      Felton, DE
      Compression difference was do the the 64cc 243 heads rather than the 67cc 241/853/806 heads
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Jul 2007
      Olathe, KS
      There were a few slight differences. The two largest being alloy type and a slight shape difference. Both changes were made to the LS6 piston to allow greater high RPM durability.
      With that being said, there would be no problem in stuffing LS1 pistons into an LS6 or vice versa.
      Felton, DE
      LS1s are internally balanced i would think the LS6 crank would be balanced different than the LS1 crank. Right?
