      Jan 2000
      Thousand Oaks California
      '68 Camaro. #2 wire off headlight switch. Where does it go?
      At the moment I can't find my chassis manual. Can someone look at a '68 Camaro manual and tell me what the brown wire that comes off pin #2 on the headlight switch goes to?
      It's getting way too hot. I think I may have a short or I have hooked something into the wrong circuit. This is also causing that coiled resister type wire to glow red hot.
      I suspect it is the dimmed dash light circuit.
      Larry Callahan
      Apr 2004
      OKC, OK
      Factory harness or AAW?
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2000
      It's a 10 year old Painless harness
      Larry Callahan
      Apr 2004
      OKC, OK
      Quote Originally Posted by Larry Callahan View Post
      that is even worse. brown should be park lights, grey would be guages, yellow dimmer, white courtesy ground, the others are not coming to mind, should be a couple more.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      May 2002
      Northern California
      yep should be park lights....if its getting hot, check to see if your lighting ground isn't loose or on paint.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
