      Oct 2008
      Richmond Texas
      87 buick gn with retro wheels
      I am looking into buying centerline retro wheels in 17x8 frt and 17x9.5 rear .i will be installing afx tall spindle and c-5 brake setup.question is will this wheel clear the calipers and what backspacing frt and rear,looking at 4" for frt and 4.75" for rear.if anyone has a g-body with these wheels pictures would be a great help.
      Aug 2006
      Cibolo, TX
      Quote Originally Posted by mak567 View Post
      Your rear backspacing is perfect. You will need to use 4.5 inch backspacing on the front to avoid rubbing (if you plan on lowering the car). There a a few other Regal owners who I am sure will chime in.
      Rob
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      Jul 2008
      Bethlehem PA
      I am running 17 X 8 front with 4.5" B.S. (with Baer Brakes).
      17 X 10 rear with 4.75 B.S. (with rolled fender lip)
      Boze Pro Touring Wheels.
      http://www.turbobuick.com/forums/2036084-post123.html
      Quote Originally Posted by T-CHRGD View Post
      Do you think the 17x10 with 5" BS would still fit on the inside to avoid rolling the lip?
      Aug 2008
      new braunfels, tx
      T-CHRGD, could you post a close up pic of your front wheel bearing cap? i wanna see how boze addresses this w/ our configuration.
      Eastern Virginia
      I think my front centerlines are 4" backspacing (can't remember for sure) & 5" backspacing rear, that is the smallest backspacing I could get with a 9.5" wide wheel.
      Scot
      86 Monte SS
