Results 1 to 14 of 14
Thread: Wheels for my 71 monte
01-06-2009 #1
Right now I'm in the process of installing new a arm bushings, 1 inch lowering springs from hotchkis, new shocks and heidt's tall 2" drop spindles.
I've been running the stock 15x7 wheels and am looking at getting some 20" torq thrust m's in black.
I'm thinking 20x10 in the rear and 20x8.5 in the front.
I know I have room for a 275/35zr20 back there because we already have two and I've stuck them up under there with about an inch of clearance on each side with them tucked way up in the fender. The wheel offset is +35mm.
Do you think they would fit with that offset?
Also, can I get some opinions on this photoshop I made? Keep in mind the front will be a bit lower with the spindles and all.
now:
20s-ish
01-06-2009 #2
- Jan 2008
- 29
wheels
I sold a set of boyd coddington smoothie wheels to a guy with a monte the fit perfect no rubbing. They were 20 x 8.5 all the way around with 255/35/20 tires.
01-06-2009 #3IMO those wheels are borderline 'DONK'. It is a big car, but 20s would only work in the back (if the car was lowered 2-4"). I would only go with 18s up front tho. Just my opinion.. and thats worth .02 or less.
Roger
01-07-2009 #4
01-07-2009 #5
01-07-2009 #6
- Oct 2006
- Corona, CA
- 1,948
