    Results 1 to 20 of 29
      which tig machine
      If one had the chance to own a miller synchrowave 200 dx or a miller 200 dynasty tig machine which one would you pick and why? I kind of like the portability of the dynasty but it doesnt seem to me very industrial like built. This is for a home shop. Thanks Chris
      Tell us about the features of each:
      Balance controls? Pulse? Post flow timer?
      From what I know, the Synchrowave is hard to beat...
      jp
      ​John Parsons
      Nov 2007
      Vancouver, WA
      Quote Originally Posted by kamaroman68 View Post
      What are you welding?
      For aluminum, the inverter welders win hands down. I've also heard of life span issues with circuit boards, etc. We use a water cooled Synchrowave 250 and an air cooled Synch 200. Considered trading the 250 for the Dynasty 200, but tough to justify the additional $$$ since the 250 is a great machine.
      1970 Dodge "E-Tikit" Challenger
      I was actually hoping for an all around machine. SS, aluminum, mild steel.
      JP I am having trouble setting up links to the 2 machines. Thanks
      Chris
      How do you like the synch 200????? Chris
      Apr 2002
      North Central Texas
      I have a 351 Syncrowave. Although it has been a few years since I have used it (not enough power in the current shop yet) it is a great welder. The only downfall for me is it requires 200 amps.
      Shannon
      Modo Innovations
      940-391-9002
      Mountain Springs, Texas
      Take a look at the current requirements of each. The inverter based Dynasty welders are a lot more efficient and only require roughly half the supply current of the transformer based syncrowave machines for a given weld current. This can be an important factor in a home shop. I also recall that the Dynasty has more capabilities and adjustability than the Syncrowave 200. That may or may not be a good thing for a novice welder in a home shop.
      Miller is pushing the Diversion 185 for home shops. It is an inverter based machine which uses the default settings of the Dynasty 200 DX.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2007
      For a home shop I would consider the HTP Invertig 201, water cooled.
      Very nice unit I have spent a lot of time on.
      WWW.SPEEDINC.COM 1957 Eldorado Brougham.......in progress
      Southern Indiana
      http://www.thermadyne.com/ also makes a few good units
      polk county,FL
      For the cost of the complete packaged dynasty dx, you could buy a syncrowave 250 which is a better machine than the dynasty imo.
      Nov 2003
      Paradise, Ca
      Quote Originally Posted by 80proZ View Post
      (snip) syncrowave 250 which is a better machine than the dynasty imo.
      In all the years the dynasty's have been out, that's the first time I've ever heard that accept from old guys who were scared of all those buttons...
      So, what is it that you like about the syncro over the dynasty? Is it the huge amount of input power that they suck up? Is it all that floor space they take up?
      Maybe you like the lack of: a pulser, sequencer, frequency adjustment, soft start, the ability to plug it into ANY power source, non-constant high frequency in AC, broader AC freq range, etc.
      Can you do a full pen, single V butt weld on 1/4" 6061 and keep your weld width to less than 3/16" in one pass with your syncro? I bet you can't.
      I just got done welding some fuel tanks for Boeing, and I can tell you that doing what we do at work with a syncro would be downright laughable.
      So now, let's hear why prefer the syncrowaves over the dynastys. I'm on pins and needles.
      And Chris, dynastys are about as bulletproof as TIG machines come. I run them everyday and have only had one problem; We had a processor board go out one day. Big whoop...Miller had it fixed 9am the next day. That's why we spend money on the blue machines. If you take your welding seriously like you should, then get the dynasty. Then get yourself a 350P. :D
      -Matt
      polk county,FL
      First,i'm really not that old.Second,buttons don't scare me either.
      Personlly i've never used any dynasty machine.But i have used other inverter based machines,and there ok.The syncro 200 is a very capable machine for the money.We use 250s at work and there great machines for what we do.
      If you make laughable welds with any machine you use you shouldn't be welding.
      So. Cal.
      If I had the bucks I would buy the Dynasty in a second. They are great machines. But the synchro will do just fine, for basic welding, no bells and whistles. And lemme say, I would love to have some bells and whistles at this point. I have a Hobart tigwave 250 and it is a great machine, but no bells or whistles. Its basically just a large power supply. It does have a low current though and that comes in handy. But from what I understand the Dynasty has a really lower range. Compare it with the synchro, it may be better at controlling lower currents and many times folks forget to look at the small end. For example, look at a really cheap imports from harbor freight, its lowest current level my be 15 amps. Hard to weld beer cans with that The synchro may be 5 amps but I remember reading years back the dynasty was 3 amps. JR
      Nov 2003
      Paradise, Ca
      So every inverter "based" TIG is exactly like a Dynasty? Wow, I was not aware of that.
      I agree that the Syncro's are very capable at a lot of things, but saying that they are great "for what we do" means absolutely nothing. What do you do? What we do is aircraft parts production, and for what we do, the Dynasty's offer incredible accuracy and stability, plus speed and versatility. None of which are traits of the Syncro's. My very first TIG setup was a Syncro 180SD and I have fond memories of that little guy, but these days I absolutely hate running anything other than an inverter.
      Don't lash out just because you're outgunned. (Ok, now you can lash out because I'm an ass) Who said anything about ultimate weld quality? I can run X-ray quality welds with either machine any day of the week, but with a Dynasty I can do it a whole lot faster and with less fuss.
      Also, please note that I never said that a Dynasty is the best choice for Chris. Only he can make that decision. I just took issue with your statements.
      -Matt
      Uh, hi Matt.
      Welcome back. Why the attitude? No need to be so harsh. It seems that the Dynasty is a better machine since it's an inverter-based technology. Good info.
      No need to say anything else.
      jp
      ​John Parsons
      Nov 2003
      Paradise, Ca
      Uh, hi Matt.
      jp
      Funny, I was about to edit my post and say how much I enjoyed riling the mods up.
      I'm not back. You know, the only reason I left this joint was out of respect for Larry. I love that dude and respect the fact that my personality doesn't jive with how he wants his message board to be run. You should know that I can't stand misinformation and people spreading the **** sandwhich that they call an opinion around like it's a fact. I've done nothing but get worse about this over the years. My disdain for the human condition is at an all time high, and yet, if you can handle a little sarcasm, you might just learn something.
      What's funny is that I know there's atleast a few people that like to see me put somebody front and center. Usually I only come here when one of your members emails me about a thread that they think I could be usefull in.
      So with that, I bid you all tootles once again. I'll check on you guys in a few months. Be good boys and girls and do what you're told.
      Edit:
      I disagree whole heartedly. People shouldn't put a lot of faith in somebody simply saying that one thing is better than another. No sir, facts, specs, and whatever other information is required to make a solid decision on things like this. With presenting facts comes disproving some opinions. Would you disagree?
      I just do it with a little flair. Do I atleast get showmanship points?
      -Matt
      Quote Originally Posted by Matt
      Do I at least get showmanship points?
      You bet. See you in a few months.
      jp
      ​John Parsons
      So. Cal.
      Quote Originally Posted by Matt@RFR View Post
      Hahaha.. Yup, yer a weldor. Ive been working around metal (sheet metal mechanic, fancy for grunt) for a few years now, and weldors (which I am not). But work with them. And my bro in law was a weldor at san onofre, my cousin is a union iron worker, and Ive enjoyed the personalities. Rubs some folks the wrong way, hell!! Not me. Guess a guy working in the office all day with a room full of women might be used to the civil water cooler talk (not saying anyone here, all men right??) might get offended. Not me. I dont get ruffled by much. OH!! Unless you talk crap about my crappy welding LOL.. No, I like some strong opinions. Milk toast anyone?? I dont drink milk or eat toast so thats where Im at. Welders?? What ever you can afford, buy the most you can afford. If its a buzz box and some soggy sticks, then thats gonna work, it has to. JR
      polk county,FL
      . :D
      With the excection of the auto link,you can get a syncro with all those options.
      I did try to do exactly what you said i couldn't do and your right.But i find it hard to believe the dynasty can.
      Some questions for ya on that one.
      Gas?
      Tungston size?
      Heat?
      What kind of bevel?Any landing?
      Got any pics?(of the weld)
      Like i said,i never used a dynasty machine,So im ignorant on what there capable of doing.I like to learn new stuff everyday,just don't be an ******* when you teach.
      Quote Originally Posted by 80Pro
      Well, if anybody could do it, it would be Matt. He's that good.
      jp
      ​John Parsons
