      Nov 2003
      St. Louis area
      18 x 11.5 wheel?
      Would an 11.5" wide wheel allow the use of a 315 or 335 tire? I would really like to run a 315/35/18 rear tire, but nobody makes that size in a street legal tire yet. CCW could make an 11.5" wide wheel that might give me the option of running either tire depending on what is available.
      Nathan
      1969 Camaro - 355 sbc, TKO 600, 12 bolt, Global West suspension
      Nov 2003
      Maine
      335
      tire rack and tire manufacturer's say a 335 can go on a 11-13 inch rim, with a 12 or 12.5 being the best fit, and not having a buldge in the side wall, also when going to an 11 it will make the 335 not much biger than a 315.
      go for it if you need a 11.5 to fit in your car, you could run either
      jake
      Louisiana
      CCW Wheels
      Here's a shot of my car with CCW 18x11.5's on the rear with 335/35/18 tires. They are the perfect match for these wheels IMO. A 315 will probably be too small.
      Nov 2002
      Georgetown,TX
      Louisiana
      Nah, just a coupe. We redesigned the rear suspension some, added some heim-jointed trailing arms and custom brackets to move them in a bit. Wouldn't have fit otherwise. This wheel/tire setup was notably more responsive than the 17x11 GS wheels I had on before.
