      Oct 2007
      MarshvilleNC
      wiring diagram, 67 camaro?
      Does anyone have a wiring diagram for the dash cluster for a 67 camaro? There is a plug that is numbered 1-12. My turn signals work but I cant get the dash lights to come on and didnt know what wire is what? Also if the ground for the cluster is in that plug? thanks guys.
      Casey
      NJ
      I have a wiring manual and a body by fisher book. I've looked through them and don't see exactly whay you are describing. That plug 1-12, is that a 12 pin plug? If so I think that I am looking at the right connection. There are several "illumination" connections there in that connector. I don't see anything about grounds. Thats if I'm even reading this correctly!!! Can you give me some more descriptions and to what colors the wires may be?
      Jun 2006
      NW burbs IL
      The ground is not in the plug, it picks up a ground from one of the bezel mounting screws. Look close at the intrument cluster and you will see a steel band that branches off to one of the mount hole locations. I mounted a wire to one of the screws at the back of the speedo and then ran the other end up under the dash, mounted with a sheetmetal screw.
      Matt
      Oct 2007
      MarshvilleNC
      Thanks guys, yea it def doesnt have any ground wires coming off the bezel anywhere. So that is what I will be doing tonight to see if that fixes the problem. But If not I might need to find out which wires coming out of that plug are supost to be hot? Thanks again guys. ill let u know if it works
      Casey
      Oct 2007
      MarshvilleNC
      Thanks!!!!!!!!
      Quote Originally Posted by Bow Tie 67 View Post
      You were right, One little ground to the cluster and bam!!! LIGHTS The turn signals started working right and the dash lights came on. I just have to hook in my gauges to the other lights and I will be done with one more part anyway. Thanks alot.
      Casey
      Jun 2006
      NW burbs IL
      Quote Originally Posted by Dream68 View Post
      No problem enjoy
      Matt
