      Oct 2007
      MarshvilleNC
      67 camaro dash lights???
      I cant seem to figure out w/ my dash lights arent coming on? Head lights, Tail Lights, turn signals and running lights all work but the only dash lights that will come on are the turn signals and they will work when you turn them on but they will also come on and stay on solid when you turn on the running lights. Any Ideas or does anyone have a dash wiring diagram that might help?? Thanks
      Casey
      A simple thing to check for is a bad ground. there are 2 screws on the bottom side and if they are loose or the plastic is chipped/cracked it will cause the cluster to do funky things(I speak from experience) hold the cluster snuglly against the dash and see if your problems go away. Mine did.
      Oct 2007
      MarshvilleNC
      ill try that thanks. But if the plastic is chipped/ cracked that shouldnt matter cause it cant ground through the plastic. I guess there is some metal mounting points where it grounds under the plastic??? thanks for the advice.
      Casey
