    Results 21 to 40 of 231
    Thread: Project-"Evade"
      Project-"Evade"
      Well its finally coming together Project "Evade" thank God for Tom Argue @ HydroIllusions! here is Project “Evade” LS2 Build specs
      LS-2
      Bore and stroke: 4.00 x 3.62 in.
      Displacement: 364 cu. in. (5.967 liters)
      Compression: 10.9:1
      Induction System: Sequential fuel injection
      Gross Horsepower (SAE net) 400 @ 6000 rpm
      Gross Torque (SAE net) 400 lb.-ft. @ 4400 rpm
      Block All-new 319-T5 Aluminum
      Livernois Heads:
      Stage 2 CNC Ported Stage 2 GM LS-Series Cylinder Heads
      New GM 243 casting
      5 axis CNC machined
      220cc Intake Runner
      Intake Flow Rate 305 CFM
      Exhaust Flow Rate 235 CFM
      2.000 intake valves / 1.550 exhaust valves
      GM valve seals and locks
      Livernois dual coil valve springs good to ~ .690 lift
      Livernois titanium retainers.--Jessel 1.7 Rollor rockers
      Livernois Motorsports LS-Series Stage 2 Camshaft
      Intake Duration 232 @ .050
      Exhaust Duration 232 @ .050
      Intake Lift .595”
      Exhaust Lift .595
      LSA 114
      Fast 92mm Intake ,Fast 92mm T.B. ,Fast Fuel Rails, 42lb Fuel Injectors, Katech Valve Covers
      AutoKraft Oil Pan & Engine Mounts, Synister Billet LS Series Serpentine Belt Systems
      SpearTech Custom Wiring Harness
      Suspension/Chassis:
      Front Sub Frame
      Speed Tech Performance • NEW Design hi clearance upper and lower control arms with Moog TM Problem Solver ball joints, QA1 single adjustable coil over shocks, QA1 coil springs, Billet aluminum upper coil over mounts, Unisteer complete rack kit.Adjustable trans cross member will fit to a T56, 1.25"solid sway bar (only works with HiClearance control arm package) ,Adjustable motor Mounts, Brakes Front: Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
      Rear Suspension Chris Alston's Chassisworks Camaro g-Bar Suspension
      With Pivot Ball Lower Link adjustable length link,
      Low-friction, pivot ball mechanisms.,G-Bar Sliding-Link Adjustable Anti-Roll Bar,VariShock Single adjustable coil-Oversm,Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
      Keisler Engineering Inc. TKO-600 5 speed Lakewood SFI Steel Bellhousing for Chevrolet LS, Hydraulic Clutch Actuator Kit
      Rear End: Strange Engineering
      S60, S/T Series 35-spline axles, 1/2” studs, Trac-Lok Posi unit, 3.73 gears
      Brakes Rear: Wilwood Disc Red 4 piston calipers Dynalite 12.19" Disc
