Results 1 to 20 of 21
Thread: Hinges w/ Fiberglass hood?
03-02-2005 #1
I have a '70 camaro and have just put a fiberglass hood on and the problem I am having is that it seems that the back of the hood isn't heavy enough to set the back of the hood all the way down. I have the light weight springs on but for some reason the back of the hinge wont go all the way down unless I push down on the backside of the hood.
03-02-2005 #2
- Nov 2004
- NW Arkansas
- 1,742
Will it go down without the low tension springs on it??????????????????
03-02-2005 #3I asked the guy doing the body work and he says it does it with or without the low tension springs
03-02-2005 #4I'd put some nice "made in Taiwan" hood pins on it for the ricer look.
Heh-what's up, Corey?
[email protected]
03-02-2005 #5
Originally Posted by gmachinz
That may work for Monte Carlo Owners
03-02-2005 #6
- Nov 2004
- NW Arkansas
- 1,742
HMMMMMMMMMMMMM! Did it go down with the factory Hood! Did you try some lubrication??
KENNY DAVIS HOTRODS
03-02-2005 #7I thought about some wd but it is going for paint here in a couple weeks and dont want any petrolium out and about. Withe the factory hood it did go down all the way but I did have the hinges powder coated and it may be just enough to hang up the hood. I just figured I would post this to see if it was a common problem or something withe the hinges.
Corey
03-02-2005 #8
- Nov 2004
- NW Arkansas
- 1,742
YEs it is especialy after powder coat! Get all the paint work done then try the wd or maybe a strategically placed shim or 2! Good luck!
KENNY DAVIS HOTRODS
03-02-2005 #9Ahhhh, SNAP! That hurt......
I can't wait to see it painted! Did you ever find out anything about the door reveal rivets? -Jabin
[email protected]
03-03-2005 #10Yes and no, The company I was going to buy them from D&R classics has a $20 min order. I only need 10 screw so that is like $4.00. So I have another post on nastyz28.com to see if anyone live in Warrenville, Illinois where D&R is located to pick them up and send them to me.
Corey
03-03-2005 #11
