      Westminster, MD
      What size jets should I run?
      I just picked up a 600 double pumper for my 355. The 355 is a mild build, 9 to 1 with small valves, RPM intake and the cam is in the .450-.460" lift and 272-278 duration range (don't remember exact specs & lost the cam card). Right now the carb has 74 primary jets and 76 secondaries which I'm thinking will be a little much for this set up right now.
      Ed Cooney
      '96 Buick Roadmaster Estate Wagon, LT1/4L60, full bolt-ons & Solomon's tune, 18" Ridler wheels, lowered with Belltech springs
      ‘70 Buick Skylark Convertible project w/ GN drivetrain
      '91 Formula, pending track day build
      Jun 2005
      Little Rock, AR
      Look up the model of your carb on Holly's website and find out what it came with out of the box. Start there.
      Felton, DE
      My holley 750 came with 72 primaries 76 secondaries. This setup was just about perfet for my 346 but its pushing about 550hp.
      I think you should run something like a 72 primary and a 74 secondary or so
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
