    Results 1 to 20 of 23
      Condensation in the garage
      I was wondering if any of you guys have a problem with condensation in your garages. THis is a metal building but I insulated it in the spring which took care of the main problem of condesation, but the weather has been going nuts around here and now I am having it again. The other night it was in the 50's after being in the upper 60's and the floor had a light amount of condensation on the floor but the underside of the camaro was dripping with water. Desided to turn the floor fan on and leave it on over night....went out last night and the car was dry underneither but the floor looked like you had poured water out on it everywhere. This is happening apparently because the air is warmer than the concrete floor since there is no open areas for water or air to enter. Have an of you guys had this problem and found a fix? I considered either tiling the floors or using those rubber tiles that summit and others sell but didn't want to waste the money if it wasn't going to help. Any suggestions?
