    Results 21 to 40 of 54
    1. #21
      Mountain View, CA
      The bigger tire volume also gives them the ability to tune the rate of each corner to enhance the jacking that is needed to get a car to corner well on an oval. Not a feature you'd want in a road-race/auto-x application.
      True T.
      My blog
    2. #22
      NorCal
      so what happens when nascar goes to sears point?
    3. #23
      Monterey Peninsula
      Quote Originally Posted by MilesSpeed View Post
      They turn left and right...?
      Sorry Liz,just couldn't resist...
      www.buickfunnycar.com
    4. #24
      La La Land, CA
      From my understanding the road race NASCAR chassis is different from the oval racing chassis. They also still use Truck arm rear suspension; not because it rocks balls either. They just seem to keep it the way it is.
      I would not put any wheel over 18 inch diameter on any car I build. For road racing, if you can put a 17" over your brakes and still clear, they still rock the most. Problem is getting a 14" setup stuffed into a 17" diameter.
      Tyler
    5. #25
      Mountain View, CA
      They go slower than they would with a different package.
      The corner weights on an oval setup are widely dissparate. This in intentional to manipulate turn-in and the ability to plant power on corner exit. Since the tire is essentially just another spring, it's pressures are used, like springs, to manipulate the corner weights.
      Now in a road race application, even in something as slow and light as a Miata tire heat will be different as well, but subtly so. If we start with equal pressures we will have usually a 2-3psi delta at T-Hill (hotter and higher on the right). So we start with the pressures a touch higher on the left-side to equalize things. With greater volume, such as in the 15" NASCAR setup, the impact of even small changes would be greater and tougher to manage.
      It's impossible to make a lap time comparison at Sears Pt. because NASCAR is the only group that runs the sissy layout.
      But if you look at Watkins Glen where the layout is the same there is a nearly 4sec difference in lap times between the NASCAR record and a Rolex DP car. The NASCAR vehicle has a huuuuuge power advantage (250-300hp difference) yet is way slower.
      True T.
      My blog
    6. #26
      League City, TX
      thanks for all the great input guys, can anyone tell me why NASCAR runs small wheels still?
      It's completely because of the rules. Many of the teams have petitioning NASCAR to change the size, (mostly do to wanting to use bigger brakes). NASCAR says it would cost too much $$$$ for all the teams to switch over and won't consider it for anytime in the near future.
      Like someone else said, NASCAR sees it as a "if the racing isn't broken, then why fix it" situation.
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
    7. #27
      Sep 2007
      Southern California
      They have a hell of time braking! The truck arm rear suspension is prone to some serious wheel hop under braking.
      Jon
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
    8. #28
      We've been over and over this subject here. Previous conclusions:
      1. No suspension design can overcome the performance disadvantages of larger wheels. Those late model Vette, Viper, and whatever wheels are costing their owners performance. It's simple: larger wheels look better to most people, so they show up on these cars. But they aren't there to increase performance.
      2. It's all about the MOI (moment of inertia) and while weight matters, diameter matters a lot more. The smallest wheels to fit your brakes are the best for performance.
      3. I found a Mazda racing spreadsheet once that attempted to turn the MOI differences into something understandable. It calculated the wheel differences into virtual weight. I no longer have that, but I remember it's conclusions: each inch of wheel diameter cost about 50 lbs in virtual weight. That's per wheel. So a car that has 17 inch wheels has something like a 200 lb advantage over an identical car with 18 inch wheels.
      jp
      ​John Parsons
    9. #29
      Farmington Hills, MI
      Quote Originally Posted by fastback View Post
      Had to post a pic of a regal.
      JEFF SHORTT
      -IDEAL STEEL
    10. #30
      Mountain View, CA
      jp
      Bingo.
      The car that won the 25hrs of Thunderhill this year was a highly modified ex-MX5 cup car. Just for kicks they decided to run tires and wheels from the Porsche Cup car that the shop also owns.
      They admit that it was a mistake to do so as it probably cost them 5-7mph at the end of the straights with no measurable difference in corner speeds. The drivers did feel like they had more grip, but the corner speeds don't reflect that and the car was not fast enough to exploit it.
      Further data point. Huge tires/wheels on a Viper Comp Coupe right? A Viper absolutely cannot pull away from a 105hp Miata between turn 1 and turn 6 at Thunderhill.
      True T.
      My blog
    11. #31
      Henderson,NV
      Bigger wheels just means more horsepower.
      Todd
    12. #32
      Mountain View, CA
      Quote Originally Posted by Vegas69 View Post
      .....that you won't be able to exploit.
      True T.
      My blog
    13. #33
      Henderson,NV
      I like the idea of a spare set for the track anyway. Be nice to have a set of R rated tires mounted up and ready to go for track days. Then you can have your desired looks on the street. That is my plan anyway.
      Todd
    14. #34
      Oct 2007
      Not to Hijack but on a related note what are the best brakes that will fit in a 17 wheel? I know it dpends on the Rim but as a general question what brake and 17 wheel combos are folks using.
      And in relation to Liz's initial ? isnt the tire options better for 17" wheels?
      And areent thier more race tires available in 17 as well
    15. #35
      Mountain View, CA
      Why don't you break that out into another thread? Once you do I'll delete your post.
      True T.
      My blog
    16. #36
      Cumberland, Maryland
      I understand the the argument of the lighter, smaller diameter wheels and I agree. The smaller the better given they cover your brakes and good rubber is available.
      So whats the market like for scuffs in 17's? 18" Cup car scuffs can be had for $200-250 a set, is there a similar market in 17" rubber?
      Price vs Performance vs Track Time. How do these things add up? Is it worth sacrificing a bit of potential performance at the expense of affordable race rubber? Of course I'm talking about open tracking or HPDE events otherwise why consider used tires. Is it potentially a feasible to want 18" wheels for a track wheels?
      18x10.5 c5 wheels aren't "that" heavy. How light is considered light by 18" standards?
    17. #37
      Mountain View, CA
      17" BFG R1's are pretty dang affordable. Within a couple bucks of Kumho and Hoosier.
      Check Tire Rack.com
      The R888 is a great tire too and quite a bit more appropriate for street use.
      True T.
      My blog
    18. #38
      NorCal
      thanks for all the great input guys! You've helped a lot! Have a happy holidays!
    19. #39
      Sep 2008
      Quote Originally Posted by GBodyGMachine View Post
      Now those would be great on me golf cart ...hehehehe
      not!
    20. #40
      Mountain View, CA
      We expect a footnote.
      True T.
      My blog
