Results 1 to 11 of 11
12-10-2008 #1
- Aug 2006
- Richland, WA
- 36
Anyone powdercoated thier LSx Blocks?
Howdy Gents:
I have an '06 LS2 with only 600 miles on it that's on an engine stand. My question is this: Has anyone powder coated thier existing blocks?
I know thermal mass is an issue (getting the entire block up to temperature) and thus you probably have to disassemble it first but I'm concerned what will happen if the block is elevated to ~400°F (powdercaoting forums say it may take several hours to get it to temperature). Given that the engine is near new and I'm not looking to build a radical engine, I would just assume reassemble the bottom end, perhaps with new bearings. I know the blocks from GMPP are coated but they have to be final machined. In a perfect world you would powdercoat first, then machine, then assemble new, but what can I say... I'm cheap and I don't see any reason to install new parts.
Any insight would be appreciated!
12-10-2008 #2
- Aug 2007
- CT
- 799
Why bother??
The bare aluminum looks mint..
12-10-2008 #3You might run into problems with the powder coat retaining more heat rather than letting the block radiate it as it might do otherwise. Least that is what I read in an article on powder coating.
12-10-2008 #4
- Nov 2006
- 7
So...Say it retains more heat. Is that comparable to how much more cast iron blocks withold? Or say a powdercoated GENI block....
12-11-2008 #5
- Dec 2004
- Dayton, Ohio
- 368
You can powder coat the the aluminum blocks. Although, it will retain heat and probably cause you more problems down the road. The alternative is to paint the block, which doesn't retain heat. There is more choices of colors than powder coat. If you prep it correctly, then it will have a better finish than powder coat. I tried powder coating my rear end (base and clear coat), and had more problems with the powder coat cracking. So I sanded the finish down and repainted it single stage paint. There is no problems with cracking now. There is no orange peel that comes with powder coating a part, and it is much cheaper.
Jeff
http://www.kodakgallery.com/67rscamaro
12-30-2008 #6
- Sep 2008
- Austin, Texas
- 72
Will probably just clean the crap out of mine and paint it BC/CC
12-30-2008 #7
