      Castro Valley, CA
      68 Camaro Subframe Alignment help
      So I tried test fitting my LS1/T56 into my 68 camro and the tranny was off to one side in the trans tunnel. Looks like it could scoot over about 2 inches. Could this be because my subframe was not aligned when I put it back on the body?
      Anyone know how I can line this thing up without having to tow it over to a frame shop?
      Thanks!
      __________________
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
      Should be reference marks or holes in the subframe. Measure diagonally to a feature and square it like you do a wall
      Newbury Park, CA
      There's likely info in the archives here, and certainly on camaros.net.
      The Body by Fisher manual has all of the needed dimensions.
      Feb 2007
      USA, TN
      There are alignment holes at the front body mounts. To properly align the frame requires cross measurements to the reference holes at the rear spring eye mounts. Two inches off is a lot. You may get an inch of movement in the frame, but I don't think you will get two inches. Do you have the correct motor mounts? Are you using big or small block engine stands? Did your LS kit come with different engine stands?
      If you still need these PM me and I can send you a copy of the actual Fisher Body drawing with the measurements. by the way don't use 69 measurements if you find them, they are different, I found out the hard way.
      1968 Camaro Crossram EFI 385, TKO 600 fully REMed. 594 hp/576 tq-ft. ATX spindles, Speedtech control arms, Chassis Works G-Link on 12 bolt with REMed gears, Chassis Works mini tubs, 245/40-17 front, 335/35-17 rear.
