      Metamora, Illinois
      Removing Seam Sealer
      I stripped the entire floorpan of my 69 Camaro with a wire wheel/media blaster. The problem is the previous owner applied an excessive amount of seam sealer directly to specific areas of the floorpans then painted/undercoated over it. Now I am using a putty knife which is REAL fun and REAL slow to remove the seam sealer. Are there any special tools, solvents, strippers, etc. that are made to remove this stuff? Any ideas/suggestions would be greatly appreciated?
      Nov 2001
      Sacramento Ca
      since you are down to bare metal, have you tried a propane torch and a wire brush?
      Tony Langlois
      1966 Corvair Monza
      Sep 2003
      Tampa, Fl
      Just having gone through this myself, the propane torch and a scraper (putty knife)worked best for me.
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
      Metamora, Illinois
      Guess I will be firing up the propnae torch tonight and see how it goes.
      Houston Texas
      wd40 worked well on mine, just let it sit. And also i used a wire brush wheel on my 4 1/2 grinder with a dusk mask and a fan venting the fumes away from me lol :rolleyes5
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      just make sure you dont cook any thing with that torch
